Old 04-07-2003, 10:57 AM   #1
7T1BURB
Engine Lift Hook(s) Location ?
Bone stock 307.....need to verify if the stock engine lift hook with the two (2) bolts that bolt to the intake manifold goes to the left front or right rear (near distributor)????? I currently have the single bolt engine lift mounted to the right rear and the double bolted lift mounted to the front left----I think I have this backwards and did not record this during disassembly prior to rebuild! Appreciate your help.....
7T1BURB is offline   Reply With Quote
Old 04-07-2003, 11:47 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
you have them in the right spot, the hook with the 2 holes goes in the left front and the single hole goes in the right rear.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 04-07-2003, 12:52 PM   #3
toms68cst
toms68cst's Avatar
Action shot that may be of interest to you!
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 04-07-2003, 12:57 PM   #4
toms68cst
toms68cst's Avatar
You can see the base of the front one just below the top radiator hose connection.
Avoid using them if you can. Mine got all bunged up during removal.
Old 04-07-2003, 12:58 PM   #5
toms68cst
toms68cst's Avatar
Forgot Picture!
Old 04-07-2003, 01:21 PM   #6
7T1BURB
Thumbs up
THANKS, ALL!!! I appreciate everyone's help-----!!
Old 04-07-2003, 01:27 PM   #7
casey
casey's Avatar
Man working with block heaters on,must have weather like we get up here, nothing like a dedicated chevy fan.
casey is offline   Reply With Quote
