Squishy brakes suddely!!
So heres the story... on my 82 k10 i was installing the pedal setup for my conversion from a th350 to a sm465 which was a pain in the
Re: Squishy brakes suddely!!
Did you use the correct length push rod? Hook the pushrod to the correct hole? If the pedal connection is positioned rearward or at a different angle the pushrod may not be working the MC until the very end of the stroke.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
Did you hook up the vaccum line to the booster?
check that plastic connection for leaks
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Yes I did im not as concerned with the boster as I am the master if the booster sh**s out the master should still work on its own but with a hard pedal. My pedal goes right to the floor almost no braking power lines have been bled several times maybe blown seals inside master? Idk
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT" 2007 cbr 1000rr ![]() |
I've seen a post some where that your front brake lines get worn out and cause that condition, but it still doesn't explain why it would decide to crap out after you disconnected the booster and master. Just saying it's worth taking a look.
78K & 79C Jimmys
find any fluid between the master and the booster
or running down from the master/booster joint area
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
nothing runing out between them levels are still the same i never seperated the two just backed them off the firewall my buddy held them i pulled my pedals out put the new in and put the combo back on the firewall...
