Will a 3/4 ton Brake Booster work on a 1/2 ton?
Im gonna have to buy a new booster and was wondering if a 3/4 ton will bolt right up to 1/2 ton brackets with no modifications, and will it improve braking?
Re: Will a 3/4 ton Brake Booster work on a 1/2 ton?
ttt
Anyone??
I believe the brackets are the same but I will get some measurements in the morning if no one confirms this. The 3/4 ton boosters work nicely on the 1/2 ton trucks. You will need the 3/4 ton MC and lines as the MC reservoirs are opposite the 1/2 ton reservoirs, (the front reservoir feeds tthe rear bracks on the 3/4 ton while the rear reservoir feeds the front). Here is a pic of the 3/4 ton setup installed in a half ton.
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Like stated, you will need the mc for the 3/4 ton as well and maybe the bracket to attach the booster. Do you already have power brakes? If not you will definitely need a booster bracket. As far as i've read though, the 3/4 ton setup will stop better due to it being designed for heavier trucks.
71 Chevy C10 350/TH350 71 GMC C20 350 (donor truck) 82 Chevy K20 Suburban 6.2/TH400/NP 95 Chevy 4x4 1500 Tahoe 6.5T/4L80E 04 Chevy 4x4 3500 Silverado 6.6T Duramax/Allison 1000 (work truck) 09 Chevy Aveo 1.6L/5 speed manual |
Member #1049
A 3/4 ton disc brake setup will work.. but you will need the following from a 3/4 ton, booster, booster mounting brackets, master cylinder and the lines from the master cylinder to prop valve.
Yes it will improve braking as the 3/4 ton booster is a dual diaphram. An easier way to go is use a 3/4 ton drum brake booster and brackets, then you can use your current master cylinder. |
Thanks, I believe this is the way I will go, can I use my 1/2 ton prop. valve too?
Member #1049
Yes, you can use your prop valve, just get a booster, brackets and rod off of a 67-70 3/4 ton..
teeitup has one for sale.. http://67-72chevytrucks.com/vboard/s...=brake+booster post #1 picture #5 |
I'm facing a similar problem, I am using a 3/4 ton cab on a 1/2 ton chassis. I mistakenly ordered a 1/2 ton booster and master cylinder. The rod on the 1/2 ton booster is about 5" long whereas the rod on the 3/4 ton is only about 3". I suspect the mounting brackets for the 1/2 ton are longer to compensate? I am going to have to pay some shipping charges to exchange unless there are some other options.
Member #1049
From what you are describing, It sounds like all you need is the booster mounting brackets from any 67-72 1/2 ton.
Like this setup. http://67-72chevytrucks.com/vboard/s...d.php?t=517694 |
are the proportioning valve different from 2WD to 4WD?
or is it just the lines that are different, do they simply cross (flip/swap) over to the front and rear fluid supply ports and using the same valve? it sure looks like in the pic above. |
Member #1049
the valves are the same 2WD or 4X4. they swap/cross lines between the
disc brake 1/2 tons and 3/4 tons. |
#13 |
Carpe manana
![]() ![]() Join Date: Dec 2010
I'm gathering parts to do this swap in my 72 Blazer and have a clarifying question:
Can the 1/2t master cylinder currently in my K5 front disc truck be used with the 3/4t booster set up I have from a disc equipped K20? In other words, do I have to buy a 3/4t MC and new lines to the prop valve or can I make use of the existing 1/2t disc brake MC/lines? I'm not sure if the rod for the MC on disc equipped trucks is as long as that on the 1/2t drum trucks. I also read that a 1/2t MC from a 1977 truck is a direct bolt up to a 3/4 booster and allows for use of existing 1/2t lines from the MC to the prop valve. Can anyone confirm this? Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 04-24-2014 at 11:28 AM. |
#14 |
Member #1049
Pete, Sorry to say that booster will not work, the 3/4 ton booster has a shorter rod than the 1/2 ton.
I do not know the answer on the 1977 m/c interchange. |
#15 |
No, the 3/4 ton master cylinder and booster are matched, rod lenth are different and matched. Also the 3/4 ton master cylinder front and rear brake lines are reversed.
#16 |
So with a 3/4 ton booster and mc on a 1/2 ton will you get sooner and a more firm pedal then with a 1/2 ton booster and mc?
#17 |
And heres another ? to throw in the mix. Is there a diffference between a big block booster and a regular 3/4 ton booster? Disc
1967custom |
#18 | ||||
Carpe manana
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#19 |
I put a lot of $ in my trucks brakes the winter of 12-13
it is a half ton cab on a 3/4 ton 4WD frame, so to make It look right I put on the 3/4 ton booster all new correct preformed lines, wheel cylinders, calipers bla bla bla IMO it don't stop any better than before, you have to push the pedal harder than newer car/truck, but it stops alright for me. |
#20 | |
Carpe manana
#21 |
So just to be clear, i just bought a 1976 K5 4x4, it has a 6" lift with 35" tires i want to convert the booster and MC to a 3/4 T setup for better braking. I have drums on the back and front disc. what exactly will i need? I dont mind buying the parts just would like to hear from someone that has already been down this road. Thanks
#22 | |
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#23 |
Anyone have any thoughts????
#24 |
Who Changed This?
![]() Join Date: Jan 2013
I haven't swapped a 3/4T master and booster for a 1/2T setup, but I think you'd be better served by putting bigger rotors on the front. Maybe the 3/4T stuff reduces pedal effort, but you're still stopping the same spinning weight.
#25 |
I have a 1971 K10 Suburban with stock 1/2 ton booster & master cylinder. Brakes are weak, an understatement. I bought a 3/4 booster/master unit. Does anyone know if the brake rod from the pedal to booster, brackets and bell crank will work with the 3/4 booster/master? I know about switching the lines from the master.
Allen |
