08-05-2011, 01:12 PM | #1 |
ZDDP.....Zinc.....Save Yourselves
This one isn't the sexiest of subjects...
We have talked about this subject before, and forgive me if there is already a "big old" thread out there staring me in the face....but this subject deserves a bunch of attention and I am sure a bunch of you guys know a whole lot more than I do on this....so inform us. I just posted this on another part of the board and figured I'd put it top and center for every ones benefit... Quote: This is (or should be) the #1 mechanical subject of discussion for us, as classic/high-performance vehicle owners. No $hit, fella's. The government has made some mandates that have affected the additives used in over the counter motor oils as of late. #1 point of concern is zinc content (which is added as a anti-scuff/abrasion and anti wear agent) in motor oils for gasoline engines. For the most part, zinc has all but been removed from these oils. ZDDP has been the silent savior for flat-tappet cams over the years. It is also responsible for early failure of catalytic converters, and since the government has mandated 100K mile minimum performance standards for cat's for 2012 emissions, oil companies are getting a jump on it....at our expense. There is quite a bit of info out there on this if you search for it. Without ZDDP in our oils you can expect cam failure in as little as the first hours of run time on new motors and engine life on our "already broke in" engines to be shortened by a factor of 20. (yes, 1/20th of normal life) There sure are ways to save our butts....Additives...some diesel oils...etc. I suggest any oils with the "SM" or "SN" designations be avoided. Brad Penn break-in oils and racing oils are formulated properly to avoid the damage inherent to these new oil's. Some synthetics also have the right stuff. Look close at the additives in your favorite oils. It has been touched on by quite a few of us lately.....but it sure needs to be taken seriously. If you ever wondered....new engine's being manufactured today have "all roller" valve trains and it's not just for the performance advantages. Learn as much as you can about this.....keep these old power plants runnin' for a few more decades.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
08-05-2011, 01:40 PM | #2 |
Re: ZDDP.....Zinc.....Save Yourselves
Brad Penn racing oils have poor ratings for zinc content. This subject is debated to death on most car boards.
I use ZDDP Plus additive and can pick whichever oil I want to put it in. |
08-05-2011, 01:50 PM | #3 |
ok... keep posting.... "we" are ready to learn more..
08-05-2011, 01:54 PM | #4 |
I knew there were some folks that knew more about this than myself...
Thanks for the feedback....and yes, bring it on...
08-05-2011, 02:37 PM | #5 |
So does anybody here want to recommend an oil to use that still has the zddp? Or should we just do as wildearp and add it?
wildearp, is ZDDP Plus the name brand of the product you use? I think people should answer here to save me the time of a google search
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348 2001 Suburban daily driver 2008 HHR (wife's ride) |
08-05-2011, 03:06 PM | #6 |
and a few others
This is all new to me, but I just googled it and came up with this article:
http://www.zddplus.com/TechBrief2%20...Oil%20Myth.pdf
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
08-05-2011, 04:46 PM | #7 |
Never Ending Projects
Castrol Syntec 20w-50 is a blend specifically for classic vehicles. It has the higher zinc levels and is classified as a speciality oil, which is why it can be sold with the higher zinc.
http://www.castrol.com/castrol/gener...tentId=7032644 Autozone is where I got mine. They didn't have enough quarts on the shelf but ordered me two cases. Not cheap as regular oil. I am likely going to use an additive when I run out as I think it is cheaper to buy regular oil and the additive but we'll see when the time comes.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-05-2011, 09:28 PM | #8 | |
I only suggested and used Brad Penns product based on their claimed mineral content... I found the possible source of your negative opinion ....and would agree with you if that info was all that was available. I did find a report from independant labs that made Penns product look a bit more attractive. Quote: Quote: ZDDP LAB RESULTS We have seen the question arise on a number of chat rooms and websites about the amount of Zinc and Phosphorous in our Penn Grade 1 High Performance Oils. The questions seem to have arose after a number of people individually sent samples of our products to Blackstone Lab(s) for analysis. The Blackstone report showed a lower Zinc and Phosphorous additive concentration level then our established in house specifications and laboratory results from our ISO 9001:2008 quality control lab proved. In an effort to clarify any misconception about our product we did our own testing and sent three virgin oil samples (each from the same identical batch) to both Blackstone Lab and Southwest Research Lab for testing. All three Southwest sample results were completely in line with our internal specifications/analysis. The Blackstone zinc and phosphorous results in all three analysis were lower than our internal specifications/analysis and Southwest Research’s lab results. The results for both the Blackstone and Southwest Research analysis are listed below: Brad Penn Product........Blackstone.......Southwest Research Penn Grade 1............zinc 1,214ppm.......zinc 1,540 ppm 20W-50 #7119...........phos 944 ppm........phos 1,319 ppm Penn Grade 1............zinc 1,424 ppm......zinc 1,565 ppm 10W-30 #7150..........phos 1,139 ppm......phos 1,332 ppm Brad Penn PCMO..........zinc 689 ppm........zinc 1,051 ppm 20W-50 SJ #7123*........phos 522 ppm........phos 901 ppm *In some cases we feel our PCMO SAE 20W-50 was sent in for analysis (and not the High Performance Oil SAE 20W-50) which does contain lower Zinc and Phosphorous additive concentration levels. We feel there is a measurement issue with Blackstone’s oil sample testing and will be addressing this with them. Please feel free to share this information on any chat site or group you belong to. For further information please [click here]. End Quote Since I'm not a real "race car driver" like some folks, I have to rely on others research and experience to form an educated opinion of my own. I've used it and still will, based on what I've been exposed to. Additives are a good way to go also.... No heavy-handed griping intended....I just thought I'd be fair to the Brad Penn group. Penn Lubricants got a raw deal from the Blackstone Lab on that occasion...and it generated some negative press that they didn't deserve. Keep smilin' and quit scuffin'.
08-05-2011, 09:36 PM | #9 |
I would use Brad Penn, as it is the old Kendall stocks prior to Witco selling out, but they only offer a synthetic or semi-synthetic oil (from what I understand) and I want to run normal dino oil.
I used Kendall GT1 15-40 for years with great results. |
08-05-2011, 09:37 PM | #10 |
Rodger on the Kendall.
08-05-2011, 09:39 PM | #11 |
Well I'm certainly no expert on the subject, but I thought I'd chime in incase it helps someone else. Near me is Advanced Auto, and they sell Rislone ZDDP additive:
http://shop.advanceautoparts.com/web...049_T|GRP60033 This is what I add to my oil when I do an oil change, and haven't had any problems yet. As someone else mentioned there is also ZDDP Plus, but I'd have to order that online as no one seems to sell that around here near me.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
08-05-2011, 10:43 PM | #12 | |
Valvoline VR-1 racing oil has the correct zinc, however, they expect you to change it every 500 miles. It may not have the proper detergents and additives for a street car. I have run it, but now use the additive. I just ordered 5 more bottles earlier this week. They are already at my house. Some diesel grade oils are supposed to have appropriate zinc levels, but that could change at any time or may have already. I ran Chevron Delo 400 15W40 in my hotrods and anything that had a flat tappet camshaft. Not for the zinc, but for the cheap price and heavy duty oil. I hadn't even heard of the zinc issue when I was running it, so I am sure I dodged a bullet on that. A friend used to give me 5 gallon buckets of it from his distributorship for..............free. Last edited by wildearp; 08-05-2011 at 10:50 PM. |
08-05-2011, 11:07 PM | #13 |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
08-05-2011, 11:17 PM | #14 |
Has anyone ever tried diesel oil. I know it may seem odd, but diesel oil has some of the metals and additives that has been taken out of regular motor oil. Just a thought
08-05-2011, 11:39 PM | #15 |
All this oils meddling has come about from a couple of issues:
First, camshafts have been evolving, to those of roller lobe profiles, which virtually eliminate the shear of the oils that flat tappet style cams produce. Shear literally squeezes the oil molecules, causing them to break down and become thinner, which gives less lubrication. Roller cams don't have the shear flat tappet cams have, so, modified lighter oils are what the manufacturers are producing. Second, older engines have things like crankshafts made of silly putty, metallurgy that is soft, compared to newer engines that have induction hardened crankshaft journals, more suited for almost no viscosity oils. Anyone ever see the 0W-15 oils some car manufacturers specify, they pour out at room temp like water, NO viscosity. They can get away with that with roller cams and induction hardened sliding surface parts. Third, emissions. The thought pattern is to remove the nasty, bad pollutants from the oils package, and add other chemicals to "enhance" lubricity in the oils, which really aren't oils any longer, they are chain chemical packages. Fourth, mileage. Roller cams, less drag inside the engine from lighter oils, all the stuff oil companies/vehicle manufacturers can advertise to con the public into believing that their snake oils, and econo-boxes get more mileage than they actually do in the real world. It is going to get far worse before we see any better in the future. Anyone see our "President" this last week or so, bleating that he and his pals want fuel mileages for vehicles, ALL vehicles, to get to 55/60 mpg by 2016? That is unrealistic, and all his plan. The government's plan is a far reaching one, literally force everyone out of their personal vehicles, and onto government supplied public transportation. One of the ways they hope to get more control is by doing NOTHING about out of control fuel prices, and with no oil drilling moratoriums in the Gulf of Mexico, off our own shores. Too bad nobody told other nations about it, they re now in OUR Gulf, drilling for, and pumping out OUR oil. |
08-06-2011, 12:54 AM | #16 |
60-66 Nut
The diesel specific oils no longer have enough ZDDP in them. Diesel engined medium duty trucks began having catalytic converters installed in 2004. The heavy duty trucks started at about the same time or slightly afterwards.
08-06-2011, 07:54 AM | #17 |
and a few others
It wasn't until 2007 for heavy trucks.
08-06-2011, 09:41 AM | #18 |
I'm using Joe Gibbs 10W-30 Synthetic Hot Rod Oil
http://www.jegs.com/i/Joe+Gibbs+Raci...01506/10002/-1 in my "66. I buy it from the local performance store for about the same price as jegs. I'll get 5k out of a oil change. I probably won't put that much in a year. So Ill just changed it one a year and the filter every 6 months.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
08-06-2011, 09:45 AM | #19 |
since we are on the oil topic.
My 1984 has always ran straight 30 weight oil. (that what my grandfather used) It has 87K on the clock. I'm thinking of switching it to Joe Gibbs oil like I use in my 66. but I dont know if I should switch it to a synthetic. What your thoughts?
08-06-2011, 11:41 AM | #20 |
the chevron delo 4oo LE (low emissions) does have the lower zinc and phosphorus levels...but the delo 400 multi grade is still the same as always for the older diesel engines, i use the multi grade at work for our older equipment and trucks. the emissions restriction were implemented for on highway trucks only, these restrictions do not include heavy equipment used for off road applications so shell and chevron as well as swepco and mobil delvac still manufacture oil for these engines here is my latest analysis for a liebherr 631 loader with 4282 hrs oil used is 15w-40 CI-4+ spec delo 400 multi grade. these are 3 sampling intervals also notice the zinc and phos content.
Hrs. 220 250 300 Iron 29 31 20 Chrm 1 0 0 Alum 1 0 0 Copp 2 1 1 Lead 1 1 2 Tin 1 0 0 Sili 6 3 5 Sod 4 3 2 Pot 0 1 0 Moly 85 50 96 Bor 10 16 2 Mag 1161 914 807 Cal 1550 1303 1182 Bar 0 0 1 Phos 1340 1006 1050 Zinc 1504 1182 1188 Soot 1.5 1.9 .4 Vis 15.3 14.4 14.7 TBN 7.4 7.04 6.19
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice Last edited by bama63; 08-06-2011 at 11:59 AM. |
08-06-2011, 04:53 PM | #21 |
Garage wrench
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
08-06-2011, 08:56 PM | #22 |
But Found Her 25yrs Later!
A song by RUSH just came to mind.
'Motor Law' Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
08-07-2011, 02:44 AM | #23 | |
08-07-2011, 02:53 AM | #24 |
I stopped at Oreilly...Schucks....For some things today...needed a qt of oil for the '63... and found myself reading every product on the shelf.....and still not having a clue what to buy.
That sure did suck.
08-07-2011, 02:57 AM | #25 |
MadMan
Rotella T 15w 40
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
