Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 08-05-2011, 02:51 PM   #1
ACII
widen the rear and front fender ???
Hello together....
on many sides you can see and buy the widen rear fenders for a chevy pu 47-53....
Had anyone ever tried to widen the front fenders ??
I think it would be a great stance with widen front and rear fenders..
Achim
ACII is offline   Reply With Quote
Old 08-05-2011, 03:33 PM   #2
duwem
duwem's Avatar
Re: widen the rear and front fender ???
Originally Posted by ACII View Post
Hello together....
Achim
Can you show me where you can get wider fenders for 47-53? I assume they are fiberglass?
duwem is offline   Reply With Quote
Old 08-05-2011, 04:24 PM   #3
ACII
you are right ....i just have seen fiberglass fender in this style..
achim
Old 08-05-2011, 04:35 PM   #4
pgf545
pgf545's Avatar
These guys have fiberglass rear fenders but I don't see any fronts on their web site. I had actually thought about splitting the fenders and adding a section but decided against it.
http://www.superiorglassworks.com/19...uct-flyer.html
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 08-05-2011, 05:15 PM   #5
63 & 64 Bowties
and a few others
you could get fenders from a one ton. They're wider, but the wheel openings are larger. But maybe you could graft the halfton openings onto the one ton fenders? I've never seen it done, so I don't know if it's possible. Just a thought.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 08-05-2011, 08:47 PM   #6
Dan Bowles
AD Addict
1 tons are not wider on the 47-55 trucks. You have to go to 1 1/2 tons to get them wider. I've swapped them from 1 tons to the 1/2 tons and vice versa with no issues. 1 1/2 tons are 4" wider but are also 4" longer with a different hood because they go up higher on the cab as well. Did BEEP ever get his 'Burb sorted out with those fenders he spliced?
Dan Bowles is offline   Reply With Quote
Old 08-05-2011, 08:52 PM   #7
BMERDOC
BMERDOC's Avatar
WIDE BODY C10!?!?!?! Shades of DTM!!! Can't picture it but I see a wing in the bed lookin like bleachers!!! Just need a German motor and a 110 point roll cage!!
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-05-2011, 09:00 PM   #8
BMERDOC
BMERDOC's Avatar
All kiding asid is it possible to stretch fat fenders like mini tubs? Take two fenders, cut the amount out of the middle of one the width you want, split the other in half and weld it all together.
Welche Größe Reifen planen Sie installieren? Was schauen willst du denn?
Nick Carter
Old 08-06-2011, 03:22 AM   #9
ACII
Hello
thanks for your answers ....your germans sounds pretty good.
At the moment i have no clue which combination i will drive.
I just would like to see any pics....
May i will do that project in the future..
Achim
Old 08-08-2011, 08:21 PM   #10
mknittle
mknittle's Avatar
i saw a thread or link here somewhere with some guys widening the fenders and cab to fit a frame they made for a corvette suspension. but I can't find it now. Rats. iwas thinking about a low mean road racer look
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 08-10-2011, 08:19 AM   #11
That is all correct. but,I believe we are talking pre-Advance Design here. I've never seen anyone selling widened fenders.
Old 08-10-2011, 12:25 PM   #12
ACII
i am not searching for a company who is selling widened fenders...
i just wanna see some pics of a truck type 3100 with widened front fenders..
compared to a ford f100 , a chevy truck is very small....so a truck with widened fenders would get a more aggressive appearance as the F100.
Regards
achim
Old 08-10-2011, 05:40 PM   #13
Do you mean F1s ('52-back) or later F100s ('53-up)? 3100?? You are wanting to see '47-1st Design GMs and earlier,right? I posted a thread with a 4wd truck that has widened fenders this morning. They're probably wider than you're thinking. I like them as they were made,personally.
http://67-72chevytrucks.com/vboard/s...d.php?t=478917
Edit: Never mind. I just read it all back over and see where my confusion comes from. This thread is in the wrong message board.
Old 08-11-2011, 02:08 PM   #14
ACII
u r right....the admin guy cancelled my second message in the 47-53 board, so the discussion was already started in this block...
maybe a admin person can move the thread into the right board
thanks
achim
Old 08-11-2011, 02:10 PM   #15
duwem
duwem's Avatar
Would love to see this as I'm doing vette suspension and thinking I may want to widen things up a little.
Old 08-11-2011, 09:28 PM   #16
thanks
achim
They deleted the one in the correct board and left this one? Look and see who moderates this message board and send a PM to move it.
