Old 08-05-2011, 05:14 PM   #1
juiceman650
juiceman650's Avatar
quick question, need help
Okay, I got my new fuel pump that came with 3 gaskets (same style and thickness), and I got some gasket sealer. My question is do I put gasket sealer on the pump, then put the gasket on, and put gasket sealer on top of the gasket as well? And how many gaskets should I use? 1, 2, or all 3?
juiceman650 is offline   Reply With Quote
Old 08-05-2011, 05:20 PM   #2
rwhit57
rwhit57's Avatar
Re: quick question, need help
One gasket, clean all the mating surfaces good, a small amount of sealer would be ok on each piece. I don't use any sealer on a fuel pump. just good clean surfaces.
rwhit57 is offline   Reply With Quote
Old 08-05-2011, 05:22 PM   #3
juiceman650
So NO sealer on the pump, just between the gasket and the block? And only ONE gasket, correct?
Old 08-05-2011, 05:46 PM   #4
rwhit57
rwhit57's Avatar
That'll be fine. Make sure you get the rod pushed back up before installing the pump.
Old 08-05-2011, 05:49 PM   #5
juiceman650
Yeah, that damn rod is being a PITA! Thanks for the help man.
Old 08-05-2011, 06:25 PM   #6
rwhit57
rwhit57's Avatar
A little grease on that rod will help hold it up. Sounds like you're kinda new at this stuff. Just take your time, don't rush it. Your welcome
Old 08-05-2011, 06:29 PM   #7
juiceman650
Yeah, I'm just 17 and its my first truck, so I'm learning still.
Old 08-06-2011, 02:59 AM   #8
67_SS396
Clean both surfaces real well and no sealer is needed. That's what the gasket is for.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
