Old 08-05-2011, 06:00 PM   #1
jimboh247
jimboh247's Avatar
Epic failure!
Managed to bust out the back glass in my '85! I'm so mad at myself!
Got a hold of a 8" diameter pipe, about 15' long. wanted to get it home before any of the other vultures at work got their hands on it. At least 1/4" wall thickness.
Thought, no problem, it will strap down just fine in the truck.
Wrong! Straps came loose and it proceeded to bust out all but one of the glass panels in the sliding back glass. It sort of rolled across the tailgate, and the end that was in the bed hit the back glass.
You had to be there to witness the stupidity.
How do you get the back glass out?
'85 SWB Silverado
jimboh247 is offline   Reply With Quote
Old 08-05-2011, 06:24 PM   #2
juiceman650
juiceman650's Avatar
Re: Epic failure!
Just grab a hammer and knock the rest out! Jk, uh I think you remove the rubber seal that holds the frame to the cab and it should pop out.
juiceman650 is offline   Reply With Quote
Old 08-05-2011, 08:16 PM   #3
Goldfinger
Goldfinger's Avatar
Re: Epic failure!
Theres a strip in the middle of the seal you must remove and it will just pop out
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 08-05-2011, 09:45 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Epic failure!
Yea been awhile but that sounds about right to me from memory. That sucks though don't you have it when dumb crap happens to ya like that?!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 08-05-2011, 10:54 PM   #5
bluex
bluex's Avatar
Re: Epic failure!
I got a solid window you could have. Looks like you would spend the same in gas as buying a new one though....
bluex is offline   Reply With Quote
Old 08-06-2011, 09:24 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Epic failure!
I did the exact same thing about 25 years ago when I had my square. Gosh was I p1$$ed at myself, I got it fixed but still was real upset for a while.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-06-2011, 10:37 AM   #7
jimboh247
jimboh247's Avatar
Re: Epic failure!
Picked up a new window for $31 from Pick-A-Part. Having a devil of a time getting it back in. I had to take a break from the frustration!
'85 SWB Silverado
Old 08-06-2011, 11:09 AM   #8
Clyde65
Clyde65's Avatar
Re: Epic failure!
how are you doing it? it always worked best for me to put the rubber around the window, then use a string inside the rubber, place the bottom of the rubber in place and push on the window gently and have someone slowly pull the string out so the rubber moves inside the cab ( does this make sence?) while you push on it from the outside.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-06-2011, 04:19 PM   #9
bluex
bluex's Avatar
Re: Epic failure!
Thats the way, lots of dish soap on the string and the rubber seal will also make it easier to get in. Be careful how much pressure you put on it....
Old 08-06-2011, 09:32 PM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Epic failure!
It's easier to put on if you have help. You want to push, sandwhich, the section you are pushing on.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
