Old 08-05-2011, 08:18 PM   #1
steverino66
firewall pad with sound deadener?
I'm debating whether I should order a new firewall pad if I'm also going to cover that part of the firewall with the foil-back-type sound deadener - ?
I haven't checked the fit of my new carpet to see how far up under the dash it will go, but I definitely don't want the shiny silver backing staring at me.
So how have you guys attacked this problem?
Firewall pad OVER the deadener? Will the stock fasteners work with both (the sound deadener I have is maybe 3/16 - 1/4" thick)?
steverino66 is offline   Reply With Quote
Old 08-05-2011, 09:48 PM   #2
chad64chevy
chad64chevy's Avatar
Re: firewall pad with sound deadener?
i was wondering the samething! i'm leaning to doing the sound deadener under the pad just to have a lil more sound an heat out of the cab, but it's more up to you i would guess!! the fasteners will be able to go thru the deadener cause it stick out about a half inch or more on the firewall side!
chad64chevy is offline   Reply With Quote
Old 08-05-2011, 09:52 PM   #3
64fleetside
i used both a stick on mat & the repro firewall pad on top of it.
64fleetside is offline   Reply With Quote
Old 08-06-2011, 09:59 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Not sure on this one but I installed carpet into my 'burb and I think it meets at the bottom of the firewall pad. I wanted it to be 12'' higher Maybe you could check with 'oem' on here and see what his original trucks have installed.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-06-2011, 11:57 AM   #5
steverino66
OK, I kind of thought what you guys are saying, but didn't want to find out the hard way I was wrong.
My original pad was the thick insulation-backed cardboard with push-through plastic fasteners, although I've seen a non-insulated rubber version for sale on a couple of sites; will stick with the original if I can make it work. Thanks.
Old 08-08-2011, 10:40 AM   #6
ratskin
I tried one of those cardboard pads-POS! I used sound deadener and foil backed pad, with carpeting. If I were to use a molded carpet and it was short, I'd get matching carpet for any exposed area. Most carpet sellers have matching carpet available-i.e. ACC and others.
ratskin is offline   Reply With Quote
Old 08-10-2011, 08:23 PM   #7
steverino66
anyone else have feedback on quality of the repro pads?
Old 08-11-2011, 11:28 AM   #8
kieth
kieth's Avatar
I would use the foil based sound deadner (I used roof repair material from home depot)
we then added a/c duct insulation that has a sticky back and a foil cover, sealed all that up with silver tape.
Then added the standard insulation pad.
We used a full length and full height rubber mat so we could do the entire floor. do not have that installed yet. but it is quiet....Kieth
kieth is offline   Reply With Quote
Old 08-11-2011, 12:30 PM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
keith, can you tell me the name of what you used for sound deadner?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-11-2011, 01:36 PM   #10
jimmydean
jimmydean's Avatar
I used Peel and Seal. Comes in a 6" wide roll for about $12 for I think 30'. It took 6 rolls to do the entire cab from the top of the gas tank to the underside of the dash. I also ran a strip on the back side of each door panel.
<edit> You can see the roll in the second picture sitting on the trans tunnel.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-11-2011, 01:59 PM   #11
Clyde65
Clyde65's Avatar
did it help? how thick is that stuff JimmyDean?
Clyde65
Rebuild of Clyde
support our troops!
Old 08-11-2011, 02:14 PM   #12
jimmydean
jimmydean's Avatar
World of difference. It has it's drawbacks, though. It melts in the heat, but so far hasn't been an issue around here, I just hope I never try to remove it. I have heard people say it stinks like roof tar when it's hot but only when new. I haven't noticed, but I also haven't been driving it.
There are better products out there that are designed to do the job. But in all honesty, unless you are building a car for sound comps it works great. If you have the coin or connections to Ram Mat or Fat Mat, I would use that instead. But when my truck is together, you won't know it's roof material under there. It is as quiet as a Cadillac. I haven't driven it since I put down my foam pad and carpet. But with just the Peel and Seal, it was a different truck.
It's about 1/8" thick or less. If you have a stereo shop near by, get a wooden roller, helps the install.
<edit> I spent under $100 for my whole floor. Deadener, 1/2" industrial carpet pad, 2 yards of top quality carpet.
Still a few wrinkles in the carpet, but it's close.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 12-13-2011, 08:56 PM   #13
dugvera@gmail.com
dugvera@gmail.com's Avatar
I like your style Jimmydean! Think outside the box and come up with something cool. Nice work Bro!
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
