K20 Suburban TBI Engine Build
'88 K20 Suburban. TBI 350. 4" lift on 35's. Dual purpose rig. We wheel it, but mostly "light", expedition-type wheeling (not a hardcore rockcrawler). We also use it for camping, and as such, I often pull a small utility-type trailer (5'x8', single axle) over the local fire roads to get to our favorite spots.
I could use some more low end torque and I was considering a few options. TBI will be the fuel delivery system on both options: OPTION 1: Keep the 350, rebuild, cam, intake, headers. Pros Already have the engine Parts are relatively inexpensive Truck is already set up w/ this engine (simplified installation) Cons Small engine, big truck Even after mods, it will still make less power that a BBC w/ the same mods OPTION 2: Swap in a 454, rebuild, cam, intake, headers. Pros Big block power right out of the box More power than a small block with what is comparatively the same cam, intake & exhaust Cons Parts cost a little more Have to deal with getting it emissions legal (CA truck) Need to source the engine and all TBI parts (nickle and dime effect) Looking to get some opinions on what engine would be a better choice for a weekend wheeler/camping/expedition rig? *Cam & intake would be from the Edelbrock Performer line of parts (or equivalent). |
Re: K20 Suburban TBI Engine Build
Bueler...Bueler...
You didn't mention what gears you have.But my 3/ton suburban has 4:10s with stock tires and it pulls a 20ft tandem with my crawler on it 70mph no problem.I am thinking you need to regear lower to gain your power back and get the engine spinning in the power range.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14, |
In the Forgotten far North.
![]() Join Date: Jul 2007
build up your 350 to a 383 stroker.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Build a stroker and use a more modern cam design. The Performer series cams are way outdated and leave a lot of useful power on the table.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
Just wondering do the mpg's matter or not but since your dealing with emissions i would just keep the 350
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
One more vote for a stroker motor. I think there is still a guy who will burn you a custom chip for those TBI motors... Gears will help too. 4.10 or 4.56. Probably 4.10 since you don't have an OD.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
