![]() Join Date: Jan 2002
67 parts wanted
I am looking for some 67 only vent windows, outer door handle and a upper door hinge. Im looking for a black and a chrome 67 only drivers side vent window assembly. Also a 67 only driver side outside door handle. Also a rebuildable upper driver side door hinge.
Also looking for a 67-72 rear white only rear step bumper. ( patina would be great)
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
Re: 67 parts wanted
ttt
Wide n'Low
![]() Join Date: Jan 2007
Re: 67 parts wanted
I have a one only Chrome/black vent window for a 67, but until i get home I don't recall if it's driver side or not. But I do believe it is. I'll post up tonight what I have.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Hand Crafted C-10
![]() Join Date: Aug 2006
Re: 67 parts wanted
If Drew doesn't have the correct side of vent windows, I've got a few to choose from as well.
I do have the door handle and hinge. I just dragged this stuff out of storage so I'll return to post pics later today after I get them cleaned up a tad. |
Re: 67 parts wanted
Thanks guys. These parts are for 67 ONLY.
Hand Crafted C-10
Re: 67 parts wanted
Here's the door handle and hinge.
EDIT: Hinge shown is not correct for 1967. See post #18 Jeepers...learn something new everyday! ![]() Handle has tiny pits on top surface, latch works smoothly. Hinge is fine. Asking $35 for both parts + shpg (9.37 USPS Priority) Gunna wait on the vents until Drew responds yay or nay. . Last edited by ETsC10; 08-13-2011 at 06:16 PM. Reason: calculated shipping |
![]() Join Date: Sep 2009
Re: 67 parts wanted
Just so I'll know... Are the 67 door hinges different? I always thought they were the same.
Thanks Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
Roadtrip!
![]() Join Date: Feb 2003
Re: 67 parts wanted
I thought they were the same also. I know the wings and handles are different.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 67 parts wanted
A while back i was trying to save a white patinaed 67 driver side top hinge. The locking part that keeps the door from folding all the way back is a little different. I had about a dozen of the 68-72s and the locking part was different. Not for sure if the holes are different, but since i was looking for everything else. I never new they were different either. Maybe it was just mine??
The Waco Kid
Re: 67 parts wanted
I am curious too. I have a pretty original 67 here, I'll look at it when I get home. Greg
Re: 67 parts wanted
If they are different then you Can teach an old dog new tricks...learn something new everyday. Greg let us know what you find.
Re: 67 parts wanted
I didnt know the handles are different! What is the difference?
#13 |
1967 C-10 SWB LS-6 T-56
![]() Join Date: Feb 2007
Re: 67 parts wanted
The pins are shorter on the backside of the button.
#14 |
Member #1049
Re: 67 parts wanted
Also the bolts that hold the handle to the door go straight in instead of at an angle, (the outside door handles are 67 only)
#15 |
Re: 67 parts wanted
One could still use the later year handles on a 67, right?
#16 |
Hand Crafted C-10
Re: 67 parts wanted
#17 |
Re: 67 parts wanted
The 67 only doors have a bracket welded in the inside. That makes the bolts go in straight and not at a angle. Also the doors have a dimple around the bolt area. The best i remember.
Got me curious what problem i had with my door hidge a couple years ago. I think it is the locking mechanism. If i get away from this OT, i will go look. Steve
#18 |
Hand Crafted C-10
Re: 67 parts wanted
As it turns out the hinges are different. The hinge I photo'd in post #6 matches a 1971 hinge.
The following pics are of the '71 hinge compared with a 1967 and a 1968. Hook not the same, landing for hook when extended was flat on later hinges; earlier has a indentation. Stop different profile. (1 & 3) Also, later model hinge has a step cast into one leg. (2) Channel for stop is longer (by a tad) on the '71. (4) Machined hole for hook is WAY longer on the '67/'68's. (5) |
#19 |
Re: 67 parts wanted
Thanks for pictures. I couldnt remember what was a little different, but i new that i couldnt use the locking part on my 67. I was trying to save my patinaed white hidge. Im sure you can use the complete hidge off of a newer model. I had a 68 truck at time and the hidge part wouldnt work off of it. I had dozens of hidges off, but all were different.
#20 |
The Waco Kid
Re: 67 parts wanted
This is what I found on the hinges also. Greg
#21 | |
Hand Crafted C-10
Re: 67 parts wanted
Thanks for adding the pics...good ones and keepers!
Never did fit and I didn't realize the '67-72 truck's hinges changed year to year until now. With your fleet of trucks and some more input, we should be well on our way to a FAQ. (Plus help for you're quest) Mark (Livrat) & I pulled the '67 & '68 hinges today off of his stock doors so we believe the pics are correct per year. One of the guys today (yes you, Gary) mentioned that some of the '67 hinges may have been leftovers from the '66 trucks. We may need some input (Pics!) from the pre-67 crowd here...the '67's may have been a mixed bag. Any pics of yours for comparison? I don't feel so bad now that I bead blasted the white patina off the '71 hinge. ..jess trying to make it look photo-pretty If I find your white patina'd hinge...it won't be molested. ![]() ET . Last edited by ETsC10; 08-13-2011 at 11:58 PM. |
#22 |
Re: 67 parts wanted
Thanks for all of yall's help. I have the white hidge 67 model fixed. I need another one for my green 67. Are the hidges that are shown yours and are they for sale. I dont really care what color.
I am waiting for the guy in the first post on vent windows to respond on the vent windows. Thanks
#23 |
Re: 67 parts wanted
ttt
#24 |
Wide n'Low
Re: 67 parts wanted
So it looks like my vent window must have sold at the last swap meet, as it is nowhere to be found in my shop.
Sorry..
#25 |
Hand Crafted C-10
Re: 67 parts wanted
OK, guess I'm up.
The following are the 5 vents I have and prices. More detailed pics are HERE. And, yes, the hinges are available...$10 each + shpg. . . VENT 1:. Nice chrome. Surface rust on corner of outer frame heavy but no rust thru. $30 + shpg Last edited by ETsC10; 08-15-2011 at 06:46 PM. |
