Old 08-06-2011, 08:41 PM   #1
timh2703
56 chevy stepside cab mounts
Ok I need a little help, I have a new cab mount set and I know the square rubber mounts go on the rear of the cab but what goes on the front mount on the outside of the frame? shims? rubber? nothing? I cant seem to find any pictures showing this. Thanks
timh2703 is offline   Reply With Quote
Old 08-06-2011, 08:55 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 56 chevy stepside cab mounts
You should have a thin rubber shim and a steel shim for the front. You may need more than one if the fenders don't line up.
dwcsr is offline   Reply With Quote
Old 08-06-2011, 09:10 PM   #3
timh2703
Ok that makes sense now! Thanks for your help Dave
Old 08-06-2011, 10:43 PM   #4
retired1
OK, my thin rubber and steel shims are square like the rear rubber mount while the front mount is round. I assumed the shims went on the rear. ??
Dick
1955 stepside
1940 Ford coupe
1972 VW Super Beetle convertible
retired1 is offline   Reply With Quote
Old 08-06-2011, 11:22 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
Dick
1955 stepside
1940 Ford coupe
You should have a square one on top of the rear mount and a round one on the bottom of the rear mount with a big washer and a bolt going up through both that screws into a captured nut.
The square or slotted steel shim goes on the front along with the thin rubber shim that looks the same and a bolt with a nut clamping them down.
Sometimes when I disassemble these trucks I find multiple shims in the front or a rectangular shim on top of the rear top mount. You can add or remove shims to help get the fenders to line up a look ok at the door.
