Old 08-06-2011, 08:44 PM   #1
zackary027
zackary027's Avatar
To swap or not to swap
my 81 stepside is pushing about 3k rpm at 65mph i feel like its turning a little too hard. i currently have a set of limited slip 3.73 in the truck but my parts truck has a set of 3.08's. would the gas mileage increase be worth swapping them or should i keep the 3.73. i do some in town driving with about 40% highway at 65 mph. im running a 350 bored .40, flattops, set of fairly decent heads. tranny is a turbo 350. tire size is 275 60 15
zackary027 is offline   Reply With Quote
Old 08-06-2011, 08:48 PM   #2
71swb4x4
71swb4x4's Avatar
Re: To swap or not to swap
A 700r4 would give you the best of both worlds, is that an option?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-06-2011, 08:54 PM   #3
zackary027
zackary027's Avatar
it could be an option later but i just built this tranny it has maby 300 miles on it
Old 08-06-2011, 08:58 PM   #4
BigRed76
BigRed76's Avatar
3.08's will definitly lower rpm's and help fuel mileage. It will hurt your acceleration a little bit, but with your tire size it wont be that bad.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-06-2011, 09:00 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
With that much highway, yea swap in the 3.08. I run that gear with a 700R4. If you were closer, I would take the 3.73 axel off your hands.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-06-2011, 09:02 PM   #6
zackary027
zackary027's Avatar
You would be surprised how many people want a 3.73 limited slip
Old 08-06-2011, 09:06 PM   #7
71swb4x4
71swb4x4's Avatar
You have an engine with what seems a few performance goodies in it, but then you want to raise your rearend gearing to get better mileage. Will you be happy with the swap?
Old 08-06-2011, 09:28 PM   #8
JaggedEdge
JaggedEdge's Avatar
According to the variables you have given (Turbo 350 {final drive ratio 1.0}, RPM, and tire size) this calculator indicates 63 mph at 3000 RPM is only achieved with 4.11 rear end gears. Perhaps your tach or speedometer is in error.
You can calculate the rpm you will need to turn with the same combination of variables with a 3.08 rear gear by trial and error in the RPM box, or using the slider tab. Just keep testing rpm numbers until you get the speed you are looking for.http://www.markwilliams.com/calculators.aspx
edit to add: you can change variables like transmission type, wheel size ect. to look at different options. This is a fantastic planning tool to use!!! A 700r4 AND 3.08's will cut your rpm in half!!!
JaggedEdge is offline   Reply With Quote
Old 08-07-2011, 12:00 AM   #9
cheepin
You have to factor in the torque convertor adding about 200rpms.Them calcs. don't do this.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
