08-06-2011, 10:31 PM | #1 |
engile oil, what do you run + additives
so I am about to change the oil in my motor and since it is the first or second change from the build( not sure what previous owner did) what do you all recommend for oil, weight to brand and do any of you guys run any additives and if so which ones and why... Since I didn't build or breakin the motor, I need to make a choice as to what to run in it...... so let me know what you run and why...... I come from a long line of diesel engines and a mild built v8 is new territory for me...
O, and how many quarts will a 350 hold with stock pan....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 Last edited by dukcaln; 08-06-2011 at 10:33 PM. Reason: add info |
08-06-2011, 10:52 PM | #2 |
Old Skool Club
Re: engile oil, what do you run + additives
5 quarts.
It's been some time since mine ran (it's on a stand in the garage). But, with the heat that we have here (around 100-110), I'd run a 20W40. Then, there are those who will tell you a 10W30 or 10W40. But, I'm old school and would probably just run a good 30W. Additives? Why? Some would knock off a quart and throw in a qt of Risolone. Additives are already in the good oils. One thing you might consider would be an oil that contains some zinc. Don't know which one's they are, but someone will let you know. It's one of those debatable topics.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-06-2011, 11:08 PM | #3 |
Grandpa in the rustmobile...
Run a oil with enough zinc content if you have a flat tappet cam!
Synthetic or non, im currently running the non synthetic vr1 racing oil by valvoline, its not in tickers FAQ but it says for flat tappet cams on the back. And it was cheap and I didnt wanna go with $10 synthetic right away.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-06-2011, 11:21 PM | #4 |
Amsoil.. to me it is the best. it is expensive. But most racing teams use it, its great for diesels. Here is some specs on the 10w40 synthetic.
PRODUCT DESCRIPTION AMSOIL Synthetic 10W-40 Motor Oil is specially formulated to provide superior protection and performance in a wide variety of demanding applications. By incorporating high-quality synthetic base stocks and a superior high-zinc additive package, AMSOIL Premium Protection Oil exceeds the needs of large and small gasoline or diesel engines in cars, motorcycles, trucks, motor homes, maintenance equipment, heavy equipment, street rods and marine applications. It is ideal for high-mileage vehicles, vehicles with flat-tappet cams and high-stress vehicles subject to hot temperatures, heavy hauling, trailer pulling or off-road use. AMSOIL Premium Protection Oil resists oxidation, neutralizes acids, inhibits corrosion, reduces wear and protects against deposits. It provides the extra anti-wear protection required by engines with flat-tappet cams and high-tension valve springs. AMSOIL Synthetic 10W-40 Premium Protection Motor Oil offers flexibility and performance beyond conventional oil for convenience and trouble-free operation. AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine. Provides Superior Wear Protection AMSOIL Synthetic 10W-40 Premium Protection Motor Oil is a high viscosity oil engineered to protect against metal-to-metal contact. It resists viscosity shear and is formulated with a heavy treatment of zinc and other anti-wear additives for excellent protection of gears, bearings, cam lobes and other high-pressure components in engines and transmissions. AMSOIL Premium Protection Synthetic Motor Oil helps extend engine life. Exceeds the Requirements of Wet Clutch Transmissions AMSOIL Premium Protection Synthetic Motor Oil contains no friction modifiers, making it ideal for motorcycles, maintenance equipment and other wet clutch transmission applications. Formulated to prevent clutch glazing and slippage, it helps insure smooth clutch engagement and long term, dependable transmission operation. AMSOIL Synthetic 10W-40 Motor Oil reduces clutch wear for extended transmission life. Resists Oxidation and High Temperature Breakdown AMSOIL Premium Protection Synthetic Motor Oil is specifically formulated to overcome the thermal deficiencies common to conventional petroleum oils. Volatilization (burn-off), oxidation and excessive deposit formation from high heat are greatly reduced. Viscosity thickening is controlled and engines run cleaner, promoting cooler operation and long engine life in air- or liquid-cooled engines. Extends Drain Intervals in Gasoline and Diesel Engines Superior AMSOIL synthetic base stock and additive technology exceeds the requirements of both gasoline and diesel engines. AMSOIL Premium Protection Motor Oil is designed to neutralize acids, disperse soot and last longer in service than conventional oils. APPLICATIONS AMSOIL Synthetic 10W-40 Premium Protection Motor Oil is a multi-use, premium synthetic lubricant for applications that require or benefit from a higher viscosity oil. It is recommended for air and liquid cooled, large or small gasoline and diesel engines, transmissions and chaincase applications where 10W-40 oil is required with any of the following specifications: •API SL, SJ, SH, SG •API CI-4 Plus, CH-4, CF, CF-2 •ISO-L-EMA • Caterpillar ECF-1 •JASO MA (Motorcycle) • MAN 271/3275 • MTU Type 2 •Cummins 20071/20072/20076/20077 • VDS-2, VDS •Mack EO-M+ • ACEA A3/B3, E3, E5 • MB 228.3, 229.1 •Detroit Diesel 93K214 MIXING AMSOIL AMSOIL Synthetic 10W-40 Premium Protection Motor Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL Synthetic Oils. SERVICE LIFE AMSOIL Synthetic 10W-40 Premium Protection Motor Oil is recommended for extended intervals in unmodified, mechanically-sound vehicles or equipment as follows: Diesel Engine Service •Normal Service - Up to 25,000 miles or one year, whichever comes first, or longer based on oil analysis. •Severe Service - Up to 15,000 miles or one year, whichever comes first, or longer based on oil analysis. Gasoline Engine Service •Normal and Severe Service - Up to 15,000 miles or one year, whichever comes first, or longer based on oil analysis. Motorcycles, Small Engines, Stationary Engines, Heavy Equipment and Other Applications •Extend drain intervals based on oil analysis or follow the manufacturer-recommended drain interval. AMSOIL Ea™ Full-Flow Oil Filters are designed for extended drain intervals. They stop smaller particles, flow more oil and last longer than regular filters. For best performance, use AMSOIL Ea™ Full-Flow Oil Filters and replace at the time of oil change. Other oil filters should be changed at standard OEM* intervals. *OEM - Original Equipment Manufacturer OIL ANALYZERS INC., 715-395-0222, is a division of AMSOIL that provides cost-effective, quality oil analysis services. For more information on product applications and service life, refer to the AMSOIL Product Recommendation and Drain Interval Guide (G1490). HEALTH & SAFETY This product is not expected to cause health concerns when used for the intended application and according to the recommendations in the Material Safety Data Sheet (MSDS). MSDS’s are available upon request at 715-392- 7101 or on the AMSOIL Website. Keep Out of Reach of Children. Don’t pollute. Return used oil to collection centers. TYPICAL PHYSICAL PROPERTIES AMSOIL High Performance Synthetic 10W-40 Motor Oil (AMO) Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 14.6 Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 90.5 Viscosity Index (ASTM D-2270) 169 CCS Viscosity @ -25°C, cP (ASTM D-5293) 5501 (-25) Pour Point °C (°F) (ASTM D-97) -44 (-47) Flash Point °C (°F) (ASTM D-92) 228 (442) Fire Point °C (°F) (ASTM D-92) 250 (482) High Temperature/High Shear @ 150°C and 1.0 X 106 s-1, cP (ASTM D 4683), cP 4.3 Four Ball Wear Test (ASTM D 4172 @ 40 kgf, 150°C, 1800 rpm, 1 hour, Scar in mm) 0.40 Noack Volatility, % weight loss (g/100g) (DIN 51581) 6.7 Total Base Number 12.1 |
08-06-2011, 11:55 PM | #5 |
well I know all about amsoil, I run it in my 500hp dmax and ran it in my twin turbo cummins at 650hp...but I want to stay cheaper but good. so with my cam and rollers I should run what oil... oldblue, is vr1 a good one for me
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
08-06-2011, 11:58 PM | #6 |
Haha im no expert AT ALL
Is your motor flat tappet cam? Theres a good thread about this hang on..
08-07-2011, 12:02 AM | #7 |
08-07-2011, 12:32 AM | #8 |
rollers for me...and will the vr1 racing have enough zinc for breaking and every day driver with the mld cam..
08-07-2011, 02:45 AM | #9 | |
My Mechanic just changed my oil and added a small bottle of Zinc Additive.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
08-07-2011, 02:53 AM | #10 |
MadMan
Rotella 15w 40
81" Shortbed C10 Full Restoration underway, who needs a budget?? LS Pro Touring Build |
08-07-2011, 04:16 AM | #11 |
50w vr1 during the summer and 10w40 vr1 other months
08-07-2011, 04:29 AM | #12 |
Laid Back
Royal purple is what I use but it's kinda spendy and I use mobile1 in my every day drivers
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
08-07-2011, 06:24 AM | #13 | |
1969 Custom 30 wrecker
I use a bottle of ZDDP with every oil change on my cars because I have all flat tappet cams.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
08-07-2011, 08:22 AM | #14 |
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
08-07-2011, 09:04 AM | #15 |
on a roller motor, any 10-30, 10-40, 15-40 oil of your choice will do a great job.
for more oil information go to www.bobistheoilguy.com |
08-07-2011, 09:11 AM | #16 |
I've just started using Joe Gibbs break in oil in my engine builds. Rotella 15w40 afterwards with a little addditive, but I'm gonna try the other Joe Gibbs stuff. We'll see how it works..
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
08-07-2011, 09:42 AM | #17 |
Does anybody know if Schaeffer's supreme 7000 is good oil to run?
08-07-2011, 10:23 AM | #18 |
X2. In a mild roller motor, any off the shelf oil of you choice will be fine. What cam are you running?
08-07-2011, 11:53 AM | #19 |
I can't offer advice on any specific brands. However, if you don't need anything with a higher viscosity than Xw-30 than don't use it.
With modern multi-viscosity oils, there really is no need to switch viscosities from season to season. I use 10w-30 year round and am considering switching to 5w-40 because my engine produces good oil pressure when cold, but when it's warmed up the gauge almost reads nothing at idle. I also have a couple cylinders burning oil so consumption is high. (I have no money for a rebuild, and I put less than 3,000 a miles a year on it anyway...) |
08-07-2011, 12:09 PM | #20 |
here is the cam I am running...... howards cam cl11025 hydraulic roller cam and lifter kit.. its a roller tappet cam with roller lifters..so i g so do I guess it qualifies as roller right.... do i need an additive
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 Last edited by dukcaln; 08-07-2011 at 12:14 PM. |
08-07-2011, 12:30 PM | #21 |
08-07-2011, 12:34 PM | #22 |
was kinda sure but wanted to be 1005 sure.... ADHD sorry.... so just to pick a weight and brand... I do run rotella t6 in my d-max.... so maybe I will try the rottela conventional oil...
08-08-2011, 01:52 AM | #23 |
MadMan
08-08-2011, 01:57 AM | #24 |
I always liked Valvoline Brand Motor Oils.
I remember 20 years ago, the rumor was NOT to use Penzoil because, it was a "Parifin (sp) Base Oil". All I could think of at the time, was an oil in my engine that had Wax in it! True or not, to THIS DAY, I wont use Penzoil.
08-08-2011, 02:12 AM | #25 | ||
"I ain't nobody, dork."
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
