08-07-2011, 01:34 PM | #1 |
power disk brakes and manual trans question
ok iv purchased an awsome 66 shortbed fleetside I will be picking up in 2 weeks and plan on doing a power disk swap shortly after getting it home. my question is what solutions to mounting the booster and brake master as well as the clutch master cylinder ? before anyone bashes me for not searching the forum , I have searched and seen vary few posts on the subject .If iv blindly missed a thread , please post a link . thank you all
Bo |
08-07-2011, 08:41 PM | #2 |
Re: power disk brakes and manual trans question
Captain Fab's bracket seems to be a popular option. I bought it and it really is a quality piece of gear. You mentioned you bought a 66 and then mention a clutch master cylinder..? Are you adding a hyd release bearing or a slave cylinder for some reason? Note that 66's did not come with slave cylinder - all mechanical clutch linkage (after 62, I believe, but don't quote me).
Here is Capt Fab's bracket: http://67-72chevytrucks.com/vboard/s...d.php?t=347484 Here is an option that includes a slave cyl setup (taint cheap though - and was designed to put power disk brakes on a truck that already had a slave cylinder, like a 62, not like yours): http://www.classicperform.com/Store/...T6062BB28D.htm |
08-07-2011, 09:07 PM | #3 |
well don't i feel like a horses behind lol ill have to double check the truck . thought for sure it was hydraulic . thank you for the reply
08-07-2011, 09:37 PM | #4 |
no worries - I went through this drill when I bought a 62, then found the bill o sale to be a fraud, then bought a 66 - so have done some shoppin for both, that's all.
If your truck has a stock brake and clutch setup currently, you have many options for the disk brake upgrade - either kits from CPP, POL, or ECE. Or, you can piece together a setup from stock parts. Here's some links: Forum disk brake ref thread for piecing it together: http://67-72chevytrucks.com/vboard/s...d.php?t=367260 Here's an ECE tech article: http://www.earlyclassic.com/Tech.asp...20That%20Truck CPP index of kits: http://www.classicperform.com/6092chevtrk.htm#4 CPP front disk kit (w/o master cyl and booster): http://www.classicperform.com/Store/...6370SWBK5S.htm The booster and master cylinder: http://www.classicperform.com/Store/...ck/6062BB2.htm My dream team front/rear disk kit from CPP:http://www.classicperform.com/Store/.../6366FRBK5.htm POL front disk kit: http://www.performanceonline.com/196...d-6-LUG-16671/ ECE kit: http://www.earlyclassic.com/catalog....version%20Kits A useful JEGs page of brake fittings: http://www.jegs.com/p/JEGS-Performan...03915/10002/-1 |
08-08-2011, 01:37 AM | #5 |
60-66 Nut
Thanks for the recommend Jocko
Although that link is for the '67-'72 version of the booster bracket. bo-w, I do have the power brake booster bracket for the '63-'66 trucks, as well as the power steering box adapter. If you decide to convert to a hydraulic clutch, I have that also. The links to each are in my signature line down below \/ \/ \/
