08-07-2011, 06:07 PM | #1 |
custom bending brake lines?
Just wondering if they had to be exactly bent as the factory or could they be different?
Thanks Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
08-07-2011, 06:27 PM | #2 |
Re: custom bending brake lines?
They can be different, also which area on the truck are you referring to? from Master/proportioning to T fitting, cross member, to rear of truck etc.?
66 GMC Suburban Custom 66 Chevy K10 Suburban |
08-07-2011, 06:31 PM | #3 |
As of right now im looking at just everything in the front of the truck. I'm going to try to copy them best as possible but might change it up if I can.
08-07-2011, 07:49 PM | #4 |
I did mine in SS. Use a few wire hangers to get the shape you want. It is alot of work if you do not have the experience but the results can be great. The route can be different.
08-07-2011, 09:13 PM | #5 | ||
"I ain't nobody, dork."
^^ Exactly.
I have bent my own before and have not followed the factory routing. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
08-07-2011, 09:15 PM | #6 |
Cruzin
do it the way you want, the flares are important to be right.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-07-2011, 10:07 PM | #7 |
I was thinking about getting the ones that are already flared
08-07-2011, 11:04 PM | #8 |
I bent and flared my own, and in the process I re-routed them away from all the heat sources.
08-07-2011, 11:40 PM | #9 |
Why away from the heat sources?
08-08-2011, 02:13 AM | #10 |
If you add headers they tend to be too close to the brake lines. They can boil your brake fluid That would not be good
72 C20 Longbed 05 1500 Z71 |
08-08-2011, 09:24 AM | #11 |
Exactly! Heat kills brakes! I really don't like the way the rear line comes up the pass side to where it goes over to the front crossmember. Way too close.
