Old 08-07-2011, 06:41 PM   #1
darkone
hub socket teeth wont grab while trying to remove rear drums HO52
Hey all, im using a napa hub socket to try and remove my hubs but the teeth wont grab. does anyone have any tricks they could suggest so i can get these fuggers off? rear end is the corporate HO52 on a chevy '70 c20
darkone is offline   Reply With Quote
Old 08-07-2011, 06:41 PM   #2
darkone
Re: hub socket teeth wont grab while trying to remove rear drums HO52
pic of the hub
Old 08-07-2011, 10:33 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it'd been a few years since I've dug into one of these... is there a lock tab washer in there?
Old 08-07-2011, 10:34 PM   #4
darkone
problem solved, flathead & hammer trick did it!
Old 08-08-2011, 12:28 AM   #5
dmack91
dmack91's Avatar
Glad to hear it. When I did mine, a cold chisel was my friend.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 08-08-2011, 02:40 AM   #6
doctrouble
doctrouble's Avatar
I did mine a couple months ago. truck hasn't moved since then.. but, i assume you need to bend that back when you put them on? lol : P What do i need to worry about if i don't?
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 08-08-2011, 08:45 PM   #7
Longhorn Man
yes they need bent back. This is a locking washer, it helps keep the nut from backing off.
If it backs off while driving, bad stuff can happen.
Old 08-08-2011, 08:48 PM   #8
vectorit
What?
vectorit's Avatar
I only use that socket for the assembly on a torque wrench.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
