Old 08-08-2011, 03:24 AM   #1
CamaroChris
4l80e wiring question.
I need help, harness and trans are from a 2000 yukon XL 2500 on the trans there is a neutral safety switch, on this "NSS" There are Two connectors. (which are ****ing GLUED in) why do they glue them? 3 harnesses I have done up were all glued! Anyway, the bottom connector has Four wires. BLK/WHT, WHT, YEL, GRY. These wires are from the neutral park switch to the PCM. the top connector has ~6 wires 2 PINK 1 PPL/WHT 2 LHT GRN 1 BLK WHERE DO THESE GO? These wires don't go to the PCM they went into the cab. I have searched tech with no luck. one should be a TCC to brake pedal? or does the TCC come from pin 33 brake switch on the blue connector?
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 08-08-2011, 01:18 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: 4l80e wiring question.
I had a custom harness made for mine, so I'm not sure which wire is which; but I can tell you that my harness eliminated a handful of the wires that went to the cab. Those were for the PRNDL indicator on the dash.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-08-2011, 03:38 PM   #3
Ackattack
Ackattack's Avatar
kinda hard to say without a wiring diagram in front of me, but what about the transfer case? I'm wondering if they went to the push button controller thing. Just an idea.
I also had a big funky connector that I believe went the the ABS module down near the tranny.
Ackattack is offline   Reply With Quote
Old 08-08-2011, 08:04 PM   #4
CamaroChris
The transfer case wiring was deleted already. I'm thinking it's reverse lights, gear selector stiff like that. I think of will delete them but I need to find what they are for first.
I LIKE TRUCKS
Old 08-09-2011, 01:15 AM   #5
tonypaul
tonypaul's Avatar
I have a 4l80e on my 7.4l Vortec in my 1968 gmc. I just pulled off the whole plastic switch off the transmission and got a kit from Lokar that attaches to the trans. It has a switch with this fork like part that will activate my reverse lights and my neurtral safety from the rod on my column shifter. Works great!
This what I got-
http://www.streetperformance.com/par...3-bl1400u.html
tonypaul is offline   Reply With Quote
Old 08-18-2011, 10:18 PM   #6
Robznob11
Robznob11's Avatar
you don't need the nutral safety switch. if you are running an aftermarket shifter it should have a micro switch for back up lights. if you have somehow reworked the linkage to use the colum shift then use that switch also The main plug you need for the tranny is the round one and I think maby two little black ones but it has been awhile since I looked I know for a fact that i took the switch off the side of the tranny and chuncked it though. I run a b&m pro ratchet 4l80e
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-22-2011, 12:45 AM   #7
Super73
Super73's Avatar
See if this is helpful..
http://www.performancetrucks.net/for...t-swap-486918/
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
