Old 08-08-2011, 10:23 AM   #1
blazer2007
is it a no no to run exhaust out back
Wanting to quiet down the blazer ,the exhaust exits in front of the rear tire but I want to run it out to the back.I like the look or the exhaust coming straight back under the bumper but was wondering if the exhaust will come in thru the back window when down
blazer2007 is offline   Reply With Quote
Old 08-08-2011, 12:27 PM   #2
blakeduren
Re: is it a no no to run exhaust out back
YES! It will come in the back window when down. Even with all the windows down it can sneak in.
Angle it at 45 degrees out or 90 degrees out of the side.
blakeduren is offline   Reply With Quote
Old 08-08-2011, 03:55 PM   #3
blazer2007
thanks
Old 08-08-2011, 05:14 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Well, now. My 88 has a single 3" behind the drivers side rear tire and it comes in and I smell it, but only when off the gas. My 83 has dual 2.5" out at each rear corner and I can never smell it, even in the back seat, but people who ride in it say they smell it(I think thats BS).
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-10-2011, 01:48 AM   #5
pmpski_1
pmpski_1's Avatar
I used to see K5s running around with tailpipes coming waaay out from behind the rear wheel and always thought it looked bad. I bet those guys never smelled exhaust. Guess what I'm thinking about doing?
pmpski_1 is offline   Reply With Quote
Old 08-10-2011, 12:57 PM   #6
OrrieG
OrrieG's Avatar
You might look at some newer truck tips that let air go in and channel or increase the flow away from the truck. I have seen them on diesels I think for the same reasons, or it might be for noise reduction.
OrrieG is offline   Reply With Quote
Old 08-11-2011, 10:39 AM   #7
camshaftgsxr
camshaftgsxr's Avatar
those tips, (ive heard them called intercooled) do alot to decrease exhaust temps at the tail pipe as well
camshaftgsxr is offline   Reply With Quote
Old 08-11-2011, 10:58 AM   #8
thirdstreettito
Resident of Here
Yes, but they create back pressure in the exhaust system. Back pressure drastically decreases the performance of a diesel engine. Gasoline engines needs back pressure in the exhaust to create vacuum. Diesel engines are compression engines, whereas gasoline engines are spark.
~Bradley~
Miss having a truck
Old 08-11-2011, 11:06 AM   #9
camshaftgsxr
Gasoline engines don't need back pressure, vacuum is created by the pistons trying to pukl in more air than the throttle body or carb/ cam will allow, these tips im talking about have slots around then to introdue fresh air into the tail pipe. I would run them in front of the rear tire to avoid the problem all together
Old 08-11-2011, 10:38 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
mine are 90 out the sides
tried straight back with a barn door burb, was ok(pic), but the gate burb, no way.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-11-2011, 10:42 PM   #11
Dalaigh
Canadian Trucker
Dalaigh's Avatar
On a suburban or k5 with the gates, I vote against straight out back just because if your sitting in traffic with the window down, the fumes will get in the truck.
On another note, why is you exhaust so low motornut?
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 08-11-2011, 11:18 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
i think it's me taking the pic
but i did think that when i first got it and others ask too
but i think it would hit otherwise
but it was on it when i bought it,not sure
but i wana go out front of the wheels under the running boards
need a better pic tho
John
Old 01-16-2012, 11:43 AM   #13
Dalaigh
Canadian Trucker
Dalaigh's Avatar
I know its a little late to say, thats alot of but's
