Old 08-08-2011, 04:16 PM   #1
XtechX
XtechX's Avatar
65 to 72 conversion question.
I put 72 front rotors on my 65, I changed every thing from the A arms out.
My question is...can I use the original tie rod ends with this rotor change or do I have to some how put 72 tie rod ends on? Thanks
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 08-08-2011, 06:00 PM   #2
XtechX
XtechX's Avatar
Re: 65 to 72 conversion question.
anyone??
Old 08-08-2011, 06:06 PM   #3
Woogeroo
You want an answer in less than 1:45 ?
Old truck boards don't move that fast.
-W
Woogeroo is offline   Reply With Quote
Old 08-08-2011, 06:13 PM   #4
XtechX
XtechX's Avatar
Sorry....just checking the post.
Old 08-08-2011, 06:18 PM   #5
jgaley69
jgaley69's Avatar
Not for sure but believe that the tie rod end size is diffrent? Atleast it is form 67-70 have one size then 71-72 are diffrent.
Jerry Galey
jgaley69 is offline   Reply With Quote
Old 08-08-2011, 06:42 PM   #6
PORKY
PORKY's Avatar
I used spindles from a 1979 C10. I think they are the same as the 1972.
I used the original 1965 center link.
Napa part#s
Tie rod ends
Inner-ES406L
Outer-ES-409-R
Sleeves-ES-2004-S
Cut 1/2" off both inner & outer on driver's side to get enough adjustment to center it all
and have same amount of turning both ways. Bolts right up.
Worked for me and was cheap.
PORKY is offline   Reply With Quote
Old 08-08-2011, 06:55 PM   #7
XtechX
XtechX's Avatar
I did a little more research on here since my post and its says that the 72 tie rod ends are bigger and a different thread than the 65, so does that sleeve you are showing a pn# for make the conversion that I think I might need?
Old 08-08-2011, 06:58 PM   #8
PORKY
PORKY's Avatar
Yes that sleeve joins those 2 new tie rod ends.
Old 08-08-2011, 07:13 PM   #9
PORKY
PORKY's Avatar
The whole mess, 4 tie rod ends and 2 sleeves from Napa was less than $90.
Old 08-08-2011, 07:27 PM   #10
XtechX
XtechX's Avatar
Red face Re: 65 to 72 conversion question.
Thanks for your help, I really appreciate it!
Old 08-08-2011, 09:30 PM   #11
likaroc13
Rollin' Old Skool
i also kept the '66 center link on mine, and i'm using stock '72 spindles...i have '72 outer tie rods and '66 inner tie rods which will be mated using POL (Performance Online) adjusting sleeves....i don't have any of it assembled yet but hopefully will in the near future
