Old 08-08-2011, 08:20 PM   #1
jgmc
Rear sway bars.... What are you running?
Just thinking of buying a rear sway bar on my truck, any ideas on which one is best.
jgmc is offline   Reply With Quote
Old 08-08-2011, 08:26 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Rear sway bars.... What are you running?
hellwig
http://www.hellwigproducts.com/produ...suv-sway-bars/
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-08-2011, 08:31 PM   #3
BMERDOC
BMERDOC's Avatar
If your on a budget check out the Camaro rear bar:
http://67-72chevytrucks.com/vboard/s...d.php?t=304267
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-08-2011, 09:49 PM   #4
Ackattack
Ackattack's Avatar
camaro bar here
Though, there was a write up somewhere, where they tested with and without a rear swaybar and they got better results in a slolum without the rear bar. But I still have mine
Ackattack is offline   Reply With Quote
Old 08-08-2011, 10:14 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
does it make the same amount of difference as a front bar!?
John
1999 Toyota Tacoma 4x4
Old 08-09-2011, 11:23 AM   #6
big_al_71
big_al_71's Avatar
I had the one from CPP for a while then when I switched my trailing arms to the squeare tubing ones it was reccomended by the guys from ECE to not put it back on as it was not necessary so I sold it to another member. When I added the sway bars front and rear it made a huge difference and when I swith the trailing ars in the rear it even made more of a differnce as there is zero body roll.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-09-2011, 12:17 PM   #7
Classic69
Love That '69
Classic69's Avatar
That's what im running...a camaro IROC rear sway bar
Pretty much, it increased the rear suspension's stiffness a bit, as well as, the rear ends resistance to roll in turns...
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 08-09-2011, 12:35 PM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I would have to say with or without on the front VS with or without on the rear that the front would be a huge difference. All of the weight of a truck is on the front and even more so if you have a decent rake. The front also travels differently with independant A arms VS trailing arms or leaf springs attached to a common axle. There is a reason why many performance cars and truck would get them at least on the front even if not on the rear.
prostreetC-10 is offline   Reply With Quote
