Old 08-08-2011, 09:51 PM   #1
chase1873
chase1873's Avatar
Need a little bit of front end advise please.
heres my question.. I plan to reuse the stock A-arms just blast them and repaint them, what is the best route to take in regards to the bushings??? they seem fine. Should I get new bushings, new shaft and bushings, or just clean them up and put them back in??? I'm on a tight budget, so if I can avoid taking them to a machine shop i will... any help is appreciated.
also, on the passenger side there is a bracket that is riveted to the crossmember. This bracket connects the upper A-arm the the crossmember and the frame. It's has been structurally compromised from rust and I want to replace it... not sure what it is call or where i can find one...
Mike
1970 C10 swb step side... needs everything.
chase1873 is offline   Reply With Quote
a-arms, control arms, front suspension.
