08-08-2011, 11:57 PM | #1 |
67-70 6 cyl 350 turbo kick down linkage
Does this have any value? 250 6 cylinder with a 350 turbo, kick down linkage. I had never seen one before with the solid linkage throttle.
08-09-2011, 12:12 AM | #2 |
Re: 67-70 6 cyl 350 turbo kick down linkage
I think you are asking what the kick down does? If so it does have value. If you are in a higher gear and press on the accelerator hard enough it will down shift to a lower gear to aid in acceleration. Its what some people call "passing gear". I think the solid rod was inliner specific.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
08-09-2011, 03:09 AM | #3 |
Yeah, I know what it does, I was more looking to see if there was any intrest in it. Most 6 cylinders were standard shift, so anyone wanting to put an automatic behind one in a 67-70 would probably need it.
Posted via Mobile Device |
08-09-2011, 07:44 PM | #4 |
Ok. Sorry, the way it was worded made it a hard read.
08-12-2011, 07:52 AM | #5 |
67-72 parts collector,…
If you are interested in selling this set-up,... look here on post #188.
http://67-72chevytrucks.com/vboard/s...=1#post4841108 Member slick copper is looking for what you have.
08-13-2011, 04:02 AM | #6 |
sure am! thanks lolife99!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
