Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-09-2011, 11:28 AM   #1
cpetersen
cpetersen's Avatar
Holley question
I have a 3310-1 which is a 780, metering blocks and 2 powervalves. I'm still having a occasionial backfire through the carb. And only when you are just giving it gas. Once every 2 weeks. Well it pops one or both powervalves everytime. I'm running a 6.5 in the front and a 8.5 in the rear. I'm running the factory jets. I'm planning on putting powervalve protection in both the front and the rear, but that still doesn't explain why it backfires from time to time. Am i running to light of powervalves? I have always ran carters and found this old carb, rebuilt it. My BBC loves it. I'm just on a learning curve here. Any help would be appreciated. Thanks
cpetersen is offline   Reply With Quote
Old 08-09-2011, 03:10 PM   #2
djracer
djracer's Avatar
Re: Holley question
What jets are in it?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-09-2011, 06:25 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Holley question
Did the 3310 come with a PV in the rear in stock form???? I'm suspectin someone has 'built' a carb out of parts which is always a dangerous thing unless you KNOW exactly what your doing.
Here's the Holley .pdf for the 3310 and calls for a #21 metering plate or 75 jets in the rear, with 67 jets in the primary with a 6.5 PV. No expert on the 3310 for sure but makes me suspect secondaries didn't have a PV and this is not the right secondary metering plate.
http://www.holley.com/data/Products/...199R9934-3.pdf
I do know in stock form the 3310 was a VERY decent street carb.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-09-2011, 07:49 PM   #4
cpetersen
cpetersen's Avatar
Re: Holley question
This one has the original metering blocks they are not plates. 76 rears and 72 fronts. With a 25 nos. I'm wondering if the pump on the front is set to lean that causes backfires to. Yeah original 780's had 2 pv's. It's good learning curve. I can't believe how many different setting there are. Truelly a performance carb. The carb guy i was asking about put the protection in it offered me $350. for it straight up. The way the economy is the guy i bought it from needed the money, i payed 125 for it. I put a kit in it for about $50.00 it runs like a champ. It just backfires from time to time. Also i don't have a vacuum gauge, i might have to light of pv's in it? The at the speed shop pulled the number for the stock setting they were 6.5 and 8.5. But if i'm pulling 12 inches i should put in 8.5 and 10.5. Any thoughts?
Old 08-09-2011, 10:12 PM   #5
djracer
djracer's Avatar
Re: Holley question
I think the jets should be more square.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-09-2011, 11:34 PM   #6
Captainfab
60-66 Nut
Re: Holley question
You have your power valves backwards. The higher hg power valve should be on the primary side. The stock setup for a 3310-1 is primary jets #72's, secondary jets #76's. Primary PV is a 10.5 and the secondary PV is a 8.5
At the very least, I would switch your power valves around and see if that helps. I have the same carb on a 454 that pulls 11-12 hg at idle. I have a 9.5 PV on the primary side, but I don't remember what is in the secondary side.
Old 08-10-2011, 05:51 AM   #7
cpetersen
cpetersen's Avatar
Re: Holley question
Thanks we will give it a run.
Old 08-10-2011, 10:17 PM   #8
cpetersen
cpetersen's Avatar
Re: Holley question
Thanks for the advise guys. Silly thing is i put it back together like i took it apart. lol Glad i ask.
Old 08-15-2011, 10:28 AM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Holley question
You sure it's a 3310? A 3310 in "original" form would not have a metering block in the rear and have a metering plate (4160 style) and is 750cfm. Then add a metering block kit for the rear to make it a 4150 style carb. The secondary metering block kits don't have a power valve in them. So it sounds like the metering block in the rear is just a metering block from the front of another carb?
Unless this carb is highly modified beyond what I'm understanding. I'm no "expert" but have played with 3310's for many years.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-15-2011, 11:50 AM   #10
Marv D
Marv D's Avatar
Re: Holley question
That's what I thought too Gary but they came in both flavors. Once I dug deep I find a listing for them with the secondary metering plate, AND the standard 4150 style metering block. Apparently even more had the block and a PV than the plate. Just the luck of what I've ran across / remembered in the ones I've messed with. Funny thing is,, I have a 'pair' of 3310's Patrick 'fixed up' for a street tunnelram sitting in boxes on a shelf. I had opened them up to make sure they were clean and dry (wipe the gaskets with vasaline) before setting them on the shelf and just assumed Patrick had modified them with a secondary block, jets and PV.
Old 08-15-2011, 02:19 PM   #11
GASoline71
GASoline71's Avatar
Re: Holley question
Thanks Marv... ya know... I've heard of cats runnin' the PV in the rear block as well. What's the benefit to it if there is one? I've never done it. Always just had the one in the stock front block.
Gary
Old 08-15-2011, 09:08 PM   #12
Marv D
Marv D's Avatar
Re: Holley question
Man,, your asking the WRONG cat about that!!! I order my carbs from Patrick at Prosystems,, then stuff a wide-band o2 in each header to see if I've screwed anything up between the time he wet flowed it, to the time I bolt it on LOL. I mean I'll change a jet to keep the A/F in the power zone,, but anything else is .
Patrick is a mechanical engineer with a proficiency in hydraulics (Air is a liquid,, fuel is a liquid, talk about a guy seeking a education in his passion!!!)
ANd that's all I NEED to know about carburators LOL. Anything more and I just
Old 08-15-2011, 11:33 PM   #13
Captainfab
60-66 Nut
Re: Holley question
The original 3310, the dash 1 was a 4150 style with a secondary metering block and a secondary power valve. The 3310-2 and sunsequent models were of the 4160 style and had just the metering plate on the secondary side. As for the advantage of running a secondary power valve, I'm not really sure on that. I'm sure prostreetC-10 will be able to answer that question
Old 08-19-2011, 11:47 PM   #14
GASoline71
GASoline71's Avatar
Re: Holley question
I learned some new stuff about the 3310's today. Great posts!
I have a carb guru in Tacoma, WA myself named. I've messed with them enough to be dangerous, and then he usually "fixes" my "work" on the carbs. I get them from him nowadays and bolt them on and go. Good to have a cat like that in your back pocket!
Gary
Old 08-20-2011, 10:04 AM   #15
cpetersen
cpetersen's Avatar
Re: Holley question
What do you mean by more square? Is there a trick to adjusting the accelerator pump?
Old 08-20-2011, 12:50 PM   #16
bigsnookmaster
bigsnookmaster's Avatar
Re: Holley question
Patrick at Pro Systems is truly a good guy, and really knows how to build a carb!
bigsnookmaster is offline   Reply With Quote
Old 08-20-2011, 07:59 PM   #17
BigDan3131
BigDan3131's Avatar
Re: Holley question
Gary
Do you have a phone number or business name? I don't want to send mine out to Sean Murphy if we have one local who is just as good.
BigDan3131 is offline   Reply With Quote
Old 08-21-2011, 01:08 AM   #18
djracer
djracer's Avatar
Re: Holley question
By more Square I mean front and rear should be closer to the same Jet.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 08-21-2011, 10:30 AM   #19
cpetersen
cpetersen's Avatar
Re: Holley question
Ok thanks. I also need to find someone who has one of those old fashion sun scopes here in PHX. Nobody i know has one, or knows how to use it. lol
Old 08-21-2011, 03:36 PM   #20
GASoline71
GASoline71's Avatar
Re: Holley question
I do... can I post it here? Or do I need to send you a PM with the name and number. He's been doin' Holley's and drag race engines since the 60's.
Gary
