Old 08-09-2011, 12:59 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
1969 GMC 6bolt with 71-72 5 bolt donor ???
just to start off thanx for any help i get..i have a 1969 gmc 6 bolt and i have a 71-72 5 bolt donor. now do i want to keep my stock front crossmember and just swap out the A arms and spindles for the 71-72 or do i swap out the whole crossmember?? thanx for all the help again...from looking on the forum it looks like you can do both im wanting to know what one is best? more easy safer _ or +
ooimpalaoo is offline   Reply With Quote
Old 08-09-2011, 01:04 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1969 GMC 6bolt with 71-72 5 bolt donor ???
I just swapped the upper/lower a-arms spindles and brakes and all on my 65
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-09-2011, 10:13 PM   #3
SCOTI
SCOTI's Avatar
Sometimes it's easier to swap it as a unit if it's ready to go 'as-is'. If you're rebuilding as you go, swapping the parts over is the way I would do it as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-10-2011, 02:26 AM   #4
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
IF you plan on having the motor out, or it's already out, it would be easier to swap the entire front cross member as one unit. I think it's only 4 bolts that hold it in. If you're doing it with the motor still in, like I did, just swap everything from the a-arms out. Don't forget all the steering components. They are different.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-10-2011, 08:32 AM   #5
SCOTI
SCOTI's Avatar
It's 14bolts; 7 per side holding the x-member in place.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2011, 08:35 PM   #6
stealthy '69
'69 Chevy SWB
I stand corrected yet again! I guess it's a good thing everyone else is here, 'cus if people relied on me, they'd all be screwed!! I'm learning every day. I should just sit back and learn.
Matt
Old 08-13-2011, 11:08 AM   #7
ooimpalaoo
ooimpalaoo's Avatar
thanx for all the info guys i got all the parts off and will have them blasted and painted then install thanx again..
