Old 08-09-2011, 05:39 PM   #1
lapaipaxxx
Need help with 86 c10 cluster lights
I have a 86 C10 6.0/4l80e that i swapped the cluster for an 90-91 suburban electric speedo. Repinned the cluster with wiring diagrams that i got from this forum. Works fine, only one problem the cluster lights turn on when ignition is on. Cant work them with headlamp swith or switch them off. Any help would be great.
lapaipaxxx is offline   Reply With Quote
Old 08-09-2011, 06:25 PM   #2
J Knight
J Knight's Avatar
Re: Need help with 86 c10 cluster lights
Sounds like you pined your plug wrong. You put a switched hot where your dash light lead from your headlight switch should go.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
