08-09-2011, 09:55 PM | #1 |
new problem,speedocable HELP PLZZZZ
hi guys.
i installed the v8 and manual tranny from 1992 chevy truck.its look that the tranny work with electric cable.so my cable will not work.and i need to keep the original speedo meter.WHAT CAN I DO????
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks --c30 1966 frame off 5 years restoration ; Finished; Chevy suburban 1958 restoration ( In progress ) 85 c10 "back to original project <Finished> " 81 c10 "back to original ( later) " 85 c10 cattleman edition lifted ( finished)> K1500 1989 full restoration ( soon ) S10 1991 in progress |
08-09-2011, 10:13 PM | #2 |
Re: new problem,speedocable HELP PLZZZZ
I know on motorcycles that you can buy an cable-to-electronic convertor. I think you should be able to find the same for what you need. I have done a ton of these conversions on old bike restorations in the past. I hope this helps. Good Luck!
08-09-2011, 10:23 PM | #3 |
I use the Abbott Cable X. It uses the electrical signal from the transmission and converts it to a motor speed that runs the mechanical speedometer.
Works well. You can also calibrate it to give the correct speed on the speedometer. http://www.abbott-tach.com/Welcome.html TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
08-09-2011, 10:32 PM | #4 |
$325. Not a cheap fix.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
08-10-2011, 10:00 AM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
are you using the NV3500?
The nV3500 from an 88 or 89 has the mechanical speedo
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 08-10-2011 at 11:01 AM. |
08-10-2011, 08:51 PM | #6 |
its a 3 speed with granny gear.
08-10-2011, 08:52 PM | #7 |
08-10-2011, 08:53 PM | #8 | |
thanks
08-10-2011, 09:23 PM | #9 | |
08-10-2011, 10:03 PM | #10 |
You didn't say you wanted cheap. I wouldn't have bothered you with a response.
As far as I can tell Dakota Digital has nothing like what you need. If I understand correctly you want to convert an electronic speed sensor on the transmission to run a cable operated mechanical speedometer. If that is correct then I know of only two solutions. 1. A motor drive like the Cable-X to convert the electronic signal to motor speed to drive the cable. 2. Convert the transmission tail-shaft to a mechanical speedometer gear drive. Either solution is +$300. Check out this thread. http://ls1tech.com/forums/conversion...onversion.html If you want cheap, throw in an electronic speedometer. TR
08-10-2011, 11:27 PM | #11 | ||
will wait.i want to see how motorcycle stuff work with our cars.and i will do it if it work. Quote:
08-11-2011, 01:57 AM | #12 |
Did I offend you just by saying it's not a cheap fix. I'm just stating a fact. Don't get upset with Q.8 just because he acknowledges my post.
08-11-2011, 09:41 PM | #13 |
If you have a cheaper alternative I'm all for it. I studied this problem for a long time before I concluded that the CableX is the cheapest solution that actually works. Then I studied some more before I broke down and bought it. I was determined to keep all the stock gages working with my LS swap.
This is not a plug and play. It takes some work to mount the box, get the correct length cable, do all the wiring, do the calibration etc. But once that was done I haven't had any trouble with it (about 7000 miles). I can't hear it running either and it is just down below the fuse block. Here is a picture of it mounted in my truck. You can see the speedo cable coming out of the lower right side. People mount the box in various places, fire wall, inner fender, behind the seat, under the dash etc. The key thing is to put it where the cable can reach the speedometer with the least number of bends, and the bends must be very gentle (big radius bends). I thought being electronics and not sealed it would be better to have it in the truck with me. It comes with a cable but of course was not the length I needed. I had to get the CableX people to make me a cable to my specific length requirements. They did that quickly. The cleanest solution is to change the transmission tail-shaft to a mechanical speedo drive but it is typically more expensive and you then don't have the electronic signal for other uses. Good luck with your build however you decide to do it. TR
