Old 04-07-2003, 08:09 PM   #1
Daves72'GMC
Question Turbo 400?
How many quarts of trans fluid does a turbo 400 take with out draining the torque converter? Thank you
Daves72'GMC is offline   Reply With Quote
Old 04-07-2003, 08:23 PM   #2
rage'nrat638
rage'nrat638's Avatar
Question
it depends if if has deep truck pan, a shallow car pan,if thers a cooler plus rad.if your looking just to change the filter..buy 6 qts you should be ok???
rage'nrat638 is offline   Reply With Quote
Old 04-07-2003, 09:40 PM   #3
LudwigTheMad
LudwigTheMad's Avatar
My 400 took 15 quarts....but that included torque converter, deep pan and cooler....
I'd say add 5 quarts, see if you have a reading, then add 1/2 quart at a time untill you can see it on the dipstick (engine running....)
Remeber that the "add" mark is 1 PINT low, not a quart.......
That's right, I'm back in the game again. No it's not pink.....
1972 Blue and White Suburban.
LudwigTheMad is offline   Reply With Quote
Old 04-07-2003, 09:49 PM   #4
Daves72'GMC
Smile
I'll try 6-quarts. It has the stock pan and has a cooler. Thank you
