Old 04-07-2003, 08:25 PM   #1
humbulay
1971 C10 LWB under const.
best ideas to relocate gastank????
I'm in the mental design phase of ripping out the suicide tank and putting it behing the rear end. I've seen a couple jobs with an access door put in the bedside...I'd like to put one in the bed floor if possible. anybody used a tank I could pick up at the local junk yard??
I see getting married as a can't lose situation........... either gonna live happily ever after or get my 1st wife outta the way
humbulay is offline   Reply With Quote
Old 04-07-2003, 11:00 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
If you can find a '67-'72 Blazer or Subruban, take the gas tank, straps, sending unit, and lines out of it. It will bolt right in behind the rear end of your truck where your spare tire once went.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-07-2003, 11:09 PM   #3
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
make sure its no rusty :-)
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-07-2003, 11:27 PM   #4
kaycee
kaycee's Avatar
Blazer tank
will work from 67-88 .Take note that they wont work for a SWB coil spring set-up with out heavy modification.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-08-2003, 12:37 AM   #5
krazy_texan
krazy_texan's Avatar
yes make sure that if you try and go with a later model blazer tank that it is for sure a later model blazer not suburban, i have an 87 suburban that we are parting and the only truck that the tank will fit in is a longhorn and at that it would still be a tight fit.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 04-08-2003, 05:42 AM   #6
72ChevyCheyenne
72ChevyCheyenne's Avatar
I put a Blazer tank in an SWB with hardly any mods.
Bill Durham
http://home.attbi.com/~bulldurham
72 Cheyenne
Restoration in progress
Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed.
72ChevyCheyenne is offline   Reply With Quote
Old 04-08-2003, 07:29 AM   #7
humbulay
does the sending unit from the 72 and later blazer tanks work with the old 67-72 guage?
Old 04-08-2003, 09:53 AM   #8
andyr354
So If I go out to the salvage yard and get a poly tank out of a late 80's blazer that will work to? Sounds allot better than searching around for an old rusty one.
Andy
1970 C10: 2WD, LWB, 350, 350 auto, Headers, Duals, Edelbrock 1406 with 2101 intake, and optional rust.
andyr354 is offline   Reply With Quote
Old 04-08-2003, 11:14 AM   #9
Mudder
Mudder's Avatar
I blieve after 86 or 87 the sending units have the fuel pump on them for FI. I know these sending units are well over 300 bucks. The one I have for an 86 is like 175. (New from GM).
Mudder is offline   Reply With Quote
Old 04-08-2003, 12:19 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You should really run a search on this topic.There have been dozens of posts on this subject over the last 4-5 years and lots of info is in the system. Good luck!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-08-2003, 01:55 PM   #11
lugnut
lugnut's Avatar
gas tank
I took a tank out of a mid '70's suburban and put it between the frame rails on my '67 Chev 4x4. Had to relocate the rear most crossmember, after that things fit nicely. I actually flipped the tank 180 degrees so the filler neck is on the driver side. I then took a gas door flap from a '78 F#@! pickup and installed that on the side of the bed. I know a guy in a body shop who made a "jig" for this setup so that worked out really well. Had to do some minor work on fuel lines etc.. but everything has worked out good so far.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 04-08-2003, 01:56 PM   #12
lugnut
lugnut's Avatar
another pic
One more pic of the gas flap
Old 04-08-2003, 02:02 PM   #13
nightmare
nightmare's Avatar
that looks good lugnut. do you have pics of the rest of the truck?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
Old 04-08-2003, 09:22 PM   #14
chevy2racr
chevy2racr's Avatar
or apic of the tank in the frame? what year suburban and what capacity is it? I know someone on here put a burb tank in a SWB 4X4 with some, uh, massageing with a BFH it was 6970SWB4X4 somethign like that is his board name
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 04-09-2003, 03:14 AM   #15
Mudder
Mudder's Avatar
31 gallon
86 Blazer tank.
Old 04-10-2003, 07:27 AM   #16
humbulay
Thats beautiful work on the fuel door, but ow do you sleep at night knowing that your Ole Chevy is part F%$#?
Old 04-10-2003, 10:42 AM   #17
Stout72
Not my good side.
Stout72's Avatar
lugnut, I'd like to see some photos of the underside. I'm considering doing the same thing.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress.
00 Suburban LT
90 Camaro RS
79 Yamaha XS1100 Special (Ol' Reliable)
Stout72 is offline   Reply With Quote
Old 04-10-2003, 10:59 AM   #18
Low87
been here longer than Liz
Low87's Avatar
The 16 gallon tank from Summit is a perfect fit (sorry, don't have the part # with me). It comes with a GM 90 ohm sending unit.
You can get GM sending units from Summit or Jegs for about $75. If you meant the in-tank fuel pumps that started in 87, then yes, those get very expensive.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-10-2003, 11:02 AM   #19
Mudder
Mudder's Avatar
75 doesnt sound that bad! 175 was from a local Chevy dealer.
