Old 08-10-2011, 08:38 PM   #1
trapperjack
trapperjack's Avatar
285/75/16's on K20?
I've been trying to find decent tires on c-list for a while now. There are lots of 285/75/16's, but they seem a bit wide. I have a couple mounted on factory steel rims, seems like they might rub up front. This is a 67 all factory 3/4 ton 4x4 with drum brakes. Any issues with this size tire? I've been searching, but get all kinds of stuff. Any help is appreciated. Will be mounted on steelies.
Thanks,
trapperjack
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 08-10-2011, 08:42 PM   #2
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: 285/75/16's on K20?
If the 67-72's have a little more clearnce then the 73-87's you will be good. I have 285/75/16's on both my 78 and 90. they never run unless im getting a little rough with them off road. And then they just kiss the fenders barely. On stock wheels they might not hit at all but mine are on 16x8 aluminum wheels.
y5mgisi is offline   Reply With Quote
Old 08-11-2011, 01:39 AM   #3
ed2552
ed2552's Avatar
I have 265/75's on our C20 and there's still a bit of room. If the 4x4 is taller it shouldn't be an issue. Only one way to know!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 08-11-2011, 06:05 AM   #4
They'll fit just fine on the rims and on the truck. They could use a slightly wider rim,but I run them on stock wheels with no problems.
Old 08-11-2011, 06:22 PM   #5
Gator70
Gator70's Avatar
Trapper, I put 265/75/16's on my K15 and I am running a little short on room in the back as far as the diameter went. It looks like the tire is getting a little close to the fender. I couldnt fit them nicely on the stock wheels (they were too narrow) and went to some alum mags that I had (came off a newer 90's GM). I ran into a problem with the offset and rubbing the tie rod.
Just some food for thought
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
Old 08-12-2011, 12:04 AM   #6
trapperjack
i have 7.50x16's on there now, the 265/75/16 is supposed to be the same height as the 7.50x16's. If i could find a good 7.50X16 I'd just get one, the other 3 are almost new, but dang, they are expensive. I can get a set of 4 used radials for the price of 1 off craigslist. Thanks for the replies.
