Old 04-07-2003, 09:51 PM   #1
ol skool 68
turnin wrenches
ol skool 68's Avatar
all 4 wheels on the ground!!!
well i finally got my frame rolling again!! pics to come soon......but i have a couple of questions........i have a 5.5/6 drop......the frame is notched.......but i need some info about shock relocators are they necessary? i saw them advertised by turner enterprises and was curious....also what about an add'l 1.5" block on the rear?? any suggestions or comments???
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 04-07-2003, 11:29 PM   #2
Chevy Wrench
former desert rat
Chevy Wrench's Avatar
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Yes, you do need shock relocators. Think of this way, in order for the shock to work properly, it needs a certain amount of, lets call it "pinion angle", just to make it simple. When you "lower" the suspension, the angle of the shock increses.If it is angled (either way) too much, you wont get the dampining you need. And the shock wont work to its full potential. I used to race dirt bikes, and if I had a suspension setup that had 12 inches of travel, I wanted to use all 12 of it. What good is 12" if you only use 9" of it? See what Im saying? I beleive a shock should be angled no more than 15 or 20 degrees. Good luck.
John
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const.
Chevy Wrench is offline   Reply With Quote
Old 04-08-2003, 12:54 PM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
hmmmm, I wish I had an answer for that one.
Anyway, are you talking about the rear shocks or the front shocks? For the rear shocks I would say you for sure need the relocator brackets. For the front I am not sure if those are necessary. That seems to be a newer item that I have not seen much feedback on. I have a 4/6 drop and my front shocks didn't change angle that I can tell.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-10-2003, 09:07 PM   #4
ol skool 68
turnin wrenches
i was actually wondering about both 1971...........i figured the rear would need the kit but was unsure about the front? the front shocks don't seems to have any problem with travel or binding???
D.M.C. -FF-
Old 04-10-2003, 09:17 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
No, but I think you'll probably need shorter shocks up front.
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 04-10-2003, 10:19 PM   #6
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
lets see some pics...
tommie is offline   Reply With Quote
