Old 08-11-2011, 03:17 PM   #1
68Stepbed
68Stepbed's Avatar
OK what do you guys think?
You really can't tell too much of a difference, really. I installed some 3/4" lowering blocks on my truck last night. Why 3/4", you ask? Well, I wanted to go a tad lower in the rear, but didn't want to spend $70+ on a set of drop blocks. While under the truck one day, I noticed I still had some U-bolt threads showing under the nuts. I had exactly 3/4" of thread, so I had a buddy of mine at a machine shop make the 3/4" blocks to use up all the threads on the U-bolts.
I like the way the rear looks now, but I feel the front needs to come down about another 1/2" now. Your thoughts?
Before:
After:
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-11-2011, 04:07 PM   #2
bigguy69
dazed and confused
bigguy69's Avatar
Re: OK what do you guys think?
Looks great! I wouldn't have thought it would have made that much of difference, but it sure did.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 08-11-2011, 04:45 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Always looks good, one of my favorite trucks.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 08-11-2011, 05:13 PM   #4
caboutin
caboutin's Avatar
perfect stance!!! :]
caboutin is offline   Reply With Quote
Old 08-11-2011, 07:26 PM   #5
pat 70/71
pat 70/71's Avatar
think it looks great good job! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 08-11-2011, 08:22 PM   #6
helldiablo
looks great..
The two most important lessons to wrenchin'-1.The only time you have too much fuel is when you're on fire-2. If something hasn't broken, it's about to--
helldiablo is offline   Reply With Quote
Old 08-11-2011, 09:04 PM   #7
bigsnookmaster
bigsnookmaster's Avatar
I think it looks great! I think you are splittin hairs to get 1/2". If your rears are larger, they kind of fill the wells. I'd take it the way it is. I have thought of puttin larger tires and wheels in mine, but I would have to rework the tubs and bedsides.( Not going to happen) Besides when you put your big self in it, it probably squats another half inch! LOL Go ahead and have your wife take a pic with you in it, you'll see! Beautiful truck!
bigsnookmaster is offline   Reply With Quote
Old 08-11-2011, 09:46 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
looks great don't let a 1/2in bother ya
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-11-2011, 09:56 PM   #9
68panelman
68panelman's Avatar
Perfect!!! leave her alone!!!
68panelman is offline   Reply With Quote
Old 08-12-2011, 05:47 AM   #10
68Stepbed
68Stepbed's Avatar
Thanks for all your comments and compliments. At first I thought it looked odd and felt the front should come down some more. That's probably because I'm used to seeing it the way it's sat for so long. After spending all day looking at it, and after reading what you guys have to say, I've decided to keep it like it is. That's why I love this board. It still has a slight rake to it, which is what I was afraid I would lose.
I took a couple better pics yesterday evening.
Matt
Old 08-12-2011, 08:21 AM   #11
I was going to say it looks fine cuz the rear makes you happy and it still has rake. So,what drop does it have now and what is the difference in front and rear tire diameters? My project will have all four tires the same and it has a 4/6 drop. I would like to have some rake and am thinking to go with either 4" rear springs or a lower front spring. Larger rear tires would do the trick but I want to be able to rotate since I plan to do some traveling in it.
Old 08-12-2011, 11:35 AM   #12
QKENUF4U
QKENUF4U's Avatar
thats a really nice truck....
QKENUF4U is offline   Reply With Quote
Old 08-12-2011, 11:50 AM   #13
Racie
I say it looks great but I did think the same thing about the front like you did as well. But still it looks great like it sits right now...
Racie is offline   Reply With Quote
Old 08-12-2011, 12:13 PM   #14
NINERS1
NINERS1's Avatar
I agree, perfect stance, i always prefered a slight rake. that is a beutiful truck you have!
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline   Reply With Quote
Old 08-12-2011, 02:20 PM   #15
68Stepbed
68Stepbed's Avatar
Tim, this puts the total drop at 3.5/5.75. Actually, with the 1/4" spacers and bracket from the ECE Super Track Bar probably puts it right at 3.5/6.
The tires are 255/50/17 Front (27")
275/55/17 Rear (29")
Matt
Old 08-12-2011, 03:55 PM   #16
faribran
i like it the way it currently looks, also.
faribran is offline   Reply With Quote
Old 08-12-2011, 04:17 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Beautiful truck and looks perfect as she sits..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-12-2011, 04:30 PM   #18
original-71
///Relaxed Atmosphere
original-71's Avatar
nicely done, i would leave it as it sits now. can i see a picture of your interior if you dont mind ?
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 08-12-2011, 04:32 PM   #19
wwotr
wwotr's Avatar
Thats a tough call in your case.
I personally like a little "Rake" to my Vehicles.
Looking at your Front Bumper, it looks fine to me.
But then I look at your "Aspect Ratio" above the Front Tire and think it needs to come down some to achiev that rake.
You had that Rake going on BEFORE you did the 3/4" drop, but now that you've dropped the rear, the Rake almost looks Flat/Straight across.
Hope I didn't confuse you too much.
Roger
ADENDUM: I went back and looked at the "After" pictures and it does have that raker.
I'd leave it alone.
Looks Drop Dead Sexy the way it is now!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 08-12-2011, 05:13 PM   #20
VA72C10
VA72C10
VA72C10's Avatar
Looks great!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-13-2011, 09:29 AM   #21
big_al_71
big_al_71's Avatar
I have to agree it looks really good as it sits. the rake on mine is being bothering me for a while just dont feel like wrenching on it I rather just enjoy it.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-14-2011, 12:29 PM   #22
bluec10
bluec10's Avatar
I really like the look. The stance is great. I like it when the truck is low enough that the tires fill-up the fender, but the whole tire is still visible. You've done a fine job on the project.
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 08-14-2011, 01:24 PM   #23
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
looks great both ways matt! Sounds like me trying to get as much as I can without buying U bolts lol
John
1999 Toyota Tacoma 4x4
