08-11-2011, 05:26 PM | #1 |
Factory Cruise Control pictures
I just bought this 1972 Longhorn with the correct cruise control on it. There has been some interest in the past about cruise, so here's some detailed pictures. Let me know if anyone needs any more pictures and I'll get them.
A few notes: 1) Engage button mounted on column cover. Assembly manual shows just to left of column. 2) Notice oil fill tube with bend in the support leg. This is for cruise trucks only. 3) Power wire plugs into "Radio" terminal on fuse box. 4) Only one loom clip on outer firewall (holds transducer cable). I think assembly shows 2. Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
08-11-2011, 05:27 PM | #2 |
Re: Factory Cruise Control pictures
more...
08-11-2011, 06:06 PM | #3 |
i need a pic of the pedal switch. thanks for the pics. This board rocks!
08-11-2011, 11:19 PM | #4 |
SWB 4x4 Collector
Josh, I wonder if the dealer just scooted the switch under the column because of the trailer brake. All of the pics of trucks equipped with the 71-72 dealer installed cruise that I have seen, have always had the switch where the assembly manual places it. Very cool, they are getting very hard to find. Take care, Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
08-11-2011, 11:27 PM | #5 |
Trevor - Not sure about the switch. I thought the P.O. may have moved it when he added the trailer brakes, but there are no extra holes drilled in this area.
Joshua
08-12-2011, 01:20 PM | #6 |
67-72=-5
Attempting same cruise install this weekend, perfect timing. thanks for the pictures. Would you have a copy of the assembly manual or a few more pictures. Also this unit came out a bb 2 wheel and going into a sb 4x4 any major differences. This set has another switch,and can't figure where it connects also a wire cable behind carb. THANKS randy
08-12-2011, 02:13 PM | #7 |
Big block and small block should be the same. As for the other switch, is it a 2-prong female terminal under the dash? If so, this is for a manual transmission application. There was a shut off switch on the clutch pedal, I think just like a brake light switch. Manual or auto used the same wiring harness. The auto trucks just had the other terminal taped up.
JQ
08-12-2011, 03:00 PM | #8 |
"brand new second-hand"
Don't mean to steal your thread but I have a factory cruise set-up from a 70 GMC and want to install in my 69 ...........do you or anyone else-happen to have a template to use to drill the correct location in the firewall for the vacuum diaphram? any info on a 69-70 set-up would also be helpful. Nice cruise set-up you have, your right they are kinda hard to find.......
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
08-12-2011, 05:05 PM | #9 | |
67-72=-5
03-11-2012, 08:45 AM | #10 |
Jashua,
GREAT FIND!!! I thought the same thing about the switch location related to the brake controller. The dealer likely installed both of them before delivery. Great Carb bracket photo!!! Dan |
03-11-2012, 10:37 AM | #11 |
HEY WE HAVE THE SAME COLOR TRUCK! lucky, i wish i had cruise...
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
03-11-2012, 12:41 PM | #12 |
Hey! Thanks very much for posting this - I've always wondered about original cruise on these trucks, have just never, ever seen it. Most excellent, and thanks for taking the time to share, pics very helpful.
