08-12-2011, 01:06 AM | #1 |
cross country move
Hey what would you recommend me checking or replacing before i try to drive my 64 GMC from Alabama to California?
engine and trans have no issues, should i check rear end or change fluids ect? |
08-12-2011, 01:10 AM | #2 |
Re: cross country move
I would check the typical wear and tear stuff. Make sure your tires are in good order. Do an oil change. Top off radiator fluid. Check the plugs to make sure they look good and replace them if they don't. Pull off the distributor cap and see if the rotor or cap has excessive wear and replace if it does.
If you have an automatic, check your trans fluid and make sure it's full. If you have power steering I'd check that, and top it off if its low. Check for any oil leaks, or radiator fluid leaks and get those taken care of. I doubt you'll need to replace rear end gear oil. Might as well check your timing and dial that in correct too if it isn't already. Basically, inspect and repair anything and everything you can at home now because nothing worse than being broken down on the side of the road in a town you are not familiar with.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
08-12-2011, 01:36 AM | #3 |
make sure you have a jack and tire iron,spare tire,tire patch/plug kit,gas can,extra belts,hoses,hose clamps,fuel pump,etc....jug of water,jumper cables,tool box...you never know what might take a poop on you...
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
08-12-2011, 01:58 AM | #4 |
Good luck man! I made the trip a few months back in my 66, FL to Arizona. It was a blast.
Here's what I did: Flushed radiator Put in a new radiator cap and t-stat installed a good quality temp and oil pressure gauge Changed oil new spark plugs topped off trans fluid new tires checked brake fluid levels and bled the brakes ----------------- I also kept extra fluids of all types in the back of the truck, as well as all of my tools. A good jack, a cheater bar, an 8 pound hammer, and some jack stands are mandatory roadside tools. Oh, and pack SEVERAL gallons of water; you never know when you might need that, especially when driving the thousand miles or so through Texas. Oh and don't forget your camera! Its a trip you won't want to forget.
Rockin' a '66 and loving every minute of it |
08-12-2011, 02:00 AM | #5 |
Also, I took replacement hoses of several sizes with me too. And good duct tape. If worse comes to worse you can always rig something up on the side of the road and ease her into the next town to get it fixed.
08-12-2011, 09:21 AM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
I might also add some board member's contact info for the trip, in case you do falter, they would be just a phone call away to help you out.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-12-2011, 09:51 AM | #7 |
I like to bring a AAA card as well as all the above.Those guys can never seem to fix anything on the road but if you need a tow, that card can be priceless. Where in Cali. are you heading?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
08-12-2011, 11:01 AM | #8 |
1961 crewcab
pack the front wheel bearings too , inspect them, and the brakes while you are in there
as stated check/top off all fluids.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-12-2011, 11:24 AM | #9 |
Who Me?
Take some cool truck pics along the way and share when you get there.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
08-13-2011, 07:47 AM | #10 |
and a few others
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
08-13-2011, 08:50 AM | #11 |
made in america
i know that the gear oil in the rear end or manual tranny isnt really something that SHOULD need to be topped off but you might want to give it a shot anyway. i just tried to drive my truck from saint marys ga to pensacola florida. bout 6 hours. 3 hours into the drive my truck bit the bullet. i towed it to the house and just the other day i finally got to takin it apart. i thought it was the rear end that had locked up on me but upon further inspection the trans decided to munch up its gears. it had maybe half a quart of fluid in there. had i checked that i might still be able to drive it. although when i checked the rear end it was just about dry as well. other than that id just do the normal stuff. really beside something major like that what else can even break? to the extent that you couldnt limp it into town anyway. maybe bring a spare fuel pump?
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes. sounds good 1964 c10-283 powerpack, 3 on the tree 2004 corvette- lowered, borla, tuned. slow my old girl 1966 c10- 305v8, t-5 sold |
08-13-2011, 09:58 AM | #12 |
I would flush the radiator and replace the rad hoses and heater hoses and tune it up. It seems whenever I see anyone broken down it is a cooling system issue most of the time.
08-13-2011, 12:48 PM | #13 |
Check The Champ, Demonstrator
Ventilated seat cushion, nothing worse than Monkey Butt after a few days. I found a 12V powered ventilated seat when I was doing deliveries, it's not air conditioning but it's better than nothing.
P.S. fuses and a few strands of wire.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
