08-12-2011, 01:42 AM | #1 |
71 motor swap.....and then some..
Ok well I guess its about time to get this started....
I'll be swapping out the 5.3/4l60e and rear end out of my 03 sierra into my 71 c10.. I bought my motor mounts from ECE on tuesday.... Ipulled the motor and trans out tonight ...everythig went pretty smooth ill post pictures tomo Posted via Mobile Device |
09-11-2011, 05:28 PM | #2 |
Has more rust than truck...
Re: 71 motor swap.....and then some..
Get her in?
09-11-2011, 05:37 PM | #3 |
Is the rear end from the newer trucks approximately the same width so they fit the 67-72 trucks? Post some pics up of your swap. Thanks
09-13-2011, 08:34 PM | #4 |
meowMEOWmeowMEOW
depends on which rear end and how new yer talkin
09-13-2011, 11:03 PM | #5 |
The initial post by grease monkey states he is going to use a 2003 rearend. Therefore can any 1999 and up rearend be used with modification in the 1967-1972 trucks. Are the track widths approximately the same?
09-15-2011, 08:55 PM | #6 |
meowMEOWmeowMEOW
from what I can find, the 03 rear track width was at 66 inches.
The 64-69 trucks lists the rear track at 60.5 Found a list on the crankshaftcoalition, i just lost the link but you can google it.
