Old 08-12-2011, 11:20 AM   #1
vectorit
What?
vectorit's Avatar
67-68 Burb side mouldings no longer hard to find!
Hooray for MAR-K!
http://www.mar-k.com/what_s_new_at_mar-k.html
I got my last piece of moulding from MAR-K a little while ago, and it was exactly like OEM and fit was perfect!
Now, for those clips to hold them on...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-12-2011, 11:31 PM   #2
eyebuzz
Licensed driver
eyebuzz's Avatar
Re: 67-68 Burb side mouldings no longer hard to find!
That is nice. Gives me hope that someday they'll have the same thing for 69-72. My daughter "climbed" out the fourth "door" window and used the molding as a foot hold and torn it off. I got it back on..but it's a little bent.
eyebuzz is offline   Reply With Quote
Old 08-13-2011, 01:10 AM   #3
dougo
dougo's Avatar
you gotta be stoked on that! you mentioned a few times in the past that you were short one piece and they were near impossible to find.
Doug
'72 GMC K2500 Suburban 4x4
dougo is offline   Reply With Quote
Old 08-13-2011, 10:26 PM   #4
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Eyebuzz:
Mar-K should have your moulding available. http://www.mar-k.com/view_our_catalog.html and scroll down to the 55-59 GM Truck Mouldings, 62-72 GM Mouldings for Fleetsides, Suburbans and Blazers, look for the Suburban mouldings for 69-72 Suburban on that pdf. Hope this helps.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 08-14-2011, 09:17 AM   #5
eyebuzz
Licensed driver
eyebuzz's Avatar
I see...nice again. Thanks.
Old 08-14-2011, 06:20 PM   #6
Mulk
Mulk's Avatar
Thanks for that link.... I had all but given up. The prior owner had drilled/screwed a couple of the pieces back onto the body.
I'm planning on taking a scotch-brite pad to mine to give them a stainless , rather than polished look. So I'm happy with the old worn pieces, but the holes are the problem. If anyone has half-way straight old pieces, and are planning to go with the new stuff, I'll be happy to take them off your hands. PM me with what sections you may have, and I'll see it's what I need
Eric
'68 C20 Suburban, Bagged with Suicide 3rd Door, and Loaded with a 396 - Under Construction
http://67-72chevytrucks.com/vboard/s...d.php?t=403690
Mulk is offline   Reply With Quote
