Old 08-12-2011, 05:51 PM   #1
Hazieview
Building Dreams out of Dimes!
Air over leaf vs triangulated 4-link with bags????
Hey guys have been constantly debating on which install I should do. I already have shackles/hangers in the back. I do not want to c-notch my frame or lower my truck anymore than it already is.
My concern is ride quality and trailer hauling capabilities.
I will be doing all required welding, fabrication, and installation required so installation fees are not a concern.
If yall had a choice which setup would u choose with everything considered including cost?
Thanks!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 08-13-2011, 04:48 AM   #2
blazinzuk
blazinzuk's Avatar
Re: Air over leaf vs triangulated 4-link with bags????
Links, end of story.
Why you stuck with the triangulated 4 link though, why not an easier to package parallel 4 link with a panhard.
I have done that on a couple newer trucks and worked out very well
Eric
89 diesel jimmy
86 crew dually
87 truggy Horton
blazinzuk is offline   Reply With Quote
Old 08-13-2011, 10:28 AM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
4 link with a panard rod. done right with good bags it'll haul more weight that stock.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 08-13-2011, 10:37 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Neither one. If your not going to C-notch then both methods are a waste of time and money. I suggest you add a small set of helper bags (AoL style) and be done with it. You will be able to adjust your ride and increase your towing capacity with minimal cash outlay.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-13-2011, 10:50 AM   #5
Hazieview
I'm trying to convince myself of the same thing...
Is the 4-link that much if a better ride?
SB400 350th
