Old 08-13-2011, 01:54 PM   #1
Youngbuck7072
Youngbuck7072's Avatar
Posi's & 14 Bolts. Such a thing? Pro's and Cons?
Do they have posi applications for 14 bolts? If so, what are the pros and cons of having one? I do alot of wheelin.
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 08-14-2011, 02:47 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Posi's & 14 Bolts. Such a thing? Pro's and Cons?
Youngster...gunna ship you over to the drive train gurus for more attention...
ETsC10 is offline   Reply With Quote
Old 08-14-2011, 02:58 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
If I remember... G80 was the factory posi for the 14 bolt... aka the Gov Bomb because they tend to detonate and destroy themselves when wheeled hard... If you do a serious amount of wheeling look into ARB for an air locker... or and aftermarket posi for medium wheeling and daily driving needs....
Rich
1972 K5 Blazer CST Click HERE
Old 08-14-2011, 03:46 AM   #4
BigDan3131
BigDan3131's Avatar
Two words Detroit Locker.
BigDan3131 is offline   Reply With Quote
Old 08-14-2011, 10:18 AM   #5
b454rat
The 14b full floater had couple different "G80s". The later govbomb and the early Eaton posi. The early one was a true posi, but are hard to find, used 73-77-ish.
The G80 in the 14ff isn't nearly as bad as the other axles. They don't go boom like the other ones do. But once they lock they lock. Detroit is the best option, will drop in an open carrier.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-14-2011, 12:14 PM   #6
C-10 simplex
Randy's also has spools for 14 bolts and may have posi units; Will report back later or maybe not depending on time managment as this rear axle really interests me.
C-10 simplex is offline   Reply With Quote
Old 08-14-2011, 12:34 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The 14 Bolt full floater is one of the best axles ever available from GM. Don't confuse the FF with the SF or the smaller 9.5" 14 bolt. I agree with Big Dan... huck a locker in it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-14-2011, 12:41 PM   #8
71blazerdetroit
x3 for locker,
(or a arb if you have the $$$ to burn, if so buy me one, please)
spool is over the top unless your trailering to the play area.
71blazerdetroit is offline   Reply With Quote
Old 08-14-2011, 08:29 PM   #9
Mr. 250r
Mr. 250r's Avatar
I would go with a yukon locker but detroit is basically 100% proven, the cons is some people don't like how they lock up on the street in a corner and i think the noise of detroit's
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-14-2011, 11:42 PM   #10
Captainfab
60-66 Nut
A Detroit Locker is a proven unit for use in offroad and will hold up to a good amount of abuse. Yes the Detroits can be a bit aggressive on the street, but I would guess to say that if you need a Detroit for what you are doing, you probably won't mind the street manners. An ARB would certainly be nice, but they are $$$. The next step up from a Detroit would be a mini spool or a full spool.
