Old 08-13-2011, 02:49 PM   #1
chase1873
chase1873's Avatar
What is this called? when can I get one?
1970 c10
This bracket is rotted and i would like to replace it.
It mounts the upper A-arm to the crossmember as well as the frame.
The mount is currently riveted on. Here are some pictures.
I looked around on the more popular parts sights and couldn't find it. If someone knows where to find it I would greatly appreciate a link.
Thanks for your time.
Mike
1970 C10 swb step side... needs everything.
chase1873 is offline   Reply With Quote
Old 08-13-2011, 03:19 PM   #2
BMERDOC
BMERDOC's Avatar
Re: What is this called? when can I get one?
You aren't gonna find anyone who reproduces this part. You'll have to find one in a junkyard or someone who is selling a frame or parting out a truck.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 08-13-2011, 03:23 PM   #3
SCOTI
SCOTI's Avatar
Originally Posted by chase1873 View Post
1970 c10
That's the upper a-arm/crossmember bracket. It is not a remanufactured part. You'll need to find another crossmember to get your needed part. See if you can find someone scrapping a crossmember or hit the wrecking yards & have them cut one off a truck out there.
Drill/knock the rivets off of yours.
Drill/knock the rivets off of the 'good' extra.
Bolt the good extra onto your crossmember.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-13-2011, 03:28 PM   #4
chase1873
chase1873's Avatar
now comes my second question, I live in northern mass on the NH border, do you guys know of any good junk yards around?? also what years will that bracket be the same, just 67-72 or others also??
Mike
Old 08-13-2011, 04:01 PM   #5
SCOTI
SCOTI's Avatar
Can't help you on your local JY scene.
The 63-72's will be the closest fit but 73-87's would prob work too since the entire c-member will swap over. I do know the 1/2 ton cross-members have 1/2" studs for the upper a-arms; the larger 3/4 & 1-tons utilize 9/16" studs. You want that part from a 1/2 ton.
I'll make a suggestion too.... Subscribe to the board & post a WTB ad (want to buy) in the classifieds. It's $25 & there's prob a member out there who would ship you one off an extra x-member. Shipping should be minimal through the usps priority pkg system since it's small enough to fit in one of their boxes.
Good luck.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-13-2011, 04:24 PM   #6
bruin_d
bruin_d's Avatar
I recommend asking the guys who have put drop members on their trucks. Somebody probably has one in their yard/garage that they're gonna throw away.
bruin_d is offline   Reply With Quote
Old 08-13-2011, 06:13 PM   #7
chase1873
chase1873's Avatar
Thanks for the help guys, I'll subscribe to the form and post a WTB add.
Mike
Old 08-13-2011, 08:39 PM   #8
Slammed50
If you cover the shipping I'll send you the one out of my '63 C10. PM me if your interested.
Check out my build thread for my '63:
http://67-72chevytrucks.com/vboard/s...49#post4806049
Slammed50 is offline   Reply With Quote
Old 08-13-2011, 08:47 PM   #9
BMERDOC
BMERDOC's Avatar
Ah, SW USA metal!!! Couldn't ask for better!!
Nick Carter
Old 08-13-2011, 09:02 PM   #10
Slammed50
I got plenty more of it too!!!! Trailing arms, cross members, rear end, all going to the scrap yard if no one speaks up!!! Don't worry, I will post it all in the parts section.
Old 08-13-2011, 09:59 PM   #11
SCOTI
SCOTI's Avatar
The board members here are what makes this site great! I would have offered but I need the extra 1/2 ton crossmember I have for another board member & the only other 'extra' I have is from my dually w/the larger upper a-arm studs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
