Old 04-08-2003, 01:16 AM   #1
69Elky
what do i need to really do to make it handle...
i'm supposed to buying a 71 gmc and should have some leftover money...
i see all the high dollar suspension components but what should i really need to handle and be able carve corners i'll be putting 17in tires on it eventully..
69Elky is offline   Reply With Quote
Old 04-08-2003, 10:28 AM   #2
slam33
slam33's Avatar
You need to remember your driving a truck. It has a high center of gravity, lots of weight, a long wheelbase, and a suspention system made to carry loads. Your not going to be able to build a canyon carver with those specs. Make sure your suspention is in great shape, no slop in the tie rods or ball joints. A good set of gas shocks, KYB has a good set. Front and rear sway bars, don't go gonzo on the rear becuse most of the weight your pushing is on the front,1 1/4 front and a 7/8 rear bar work best. Alloy wheels and a set of low profile tires will help. I would go with some 60's or 50's. If you want to go further with it, then X-brace the frame, pull as mush weight off it as possible, fiberglass body parts are great Drop it a few inches, a 2/4 slam would work. leave the tank in the cab or get some saddle tanks, keep the weight between the axles. Set the motor back as far as possible. If your looking to run circles around Hondas and Vette, your better off with a well preped 68 Camero than a truck.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 04-08-2003, 09:04 PM   #3
69Elky
we've got a 68 camaro and a 98 mustang 4.6 for canyon carving i just can't drive them that often and like to be able to some enthusiastic driving while up in mountains, going up to my buddies cabin etc...
Old 04-09-2003, 07:53 AM   #4
MOTHERTRUCKERS
Not sure about the last 2 posts but for a little performance upgrade to your TRUCK a good combination is progressive rate shocks like DOETSCHTECH and EIBACH progressive rate lowering coils with HELLWIG or TRW 3/4 ton swaybars on a 1/2 ton. Also MOOG suspension will tighten up the front end and a MOOG steering stabilizer will help with the big front tires.
If for some reason you need to do some canyon carving QA1 coilovers and a rear independent suspension ala jag or vette with weight jacks and ALLSTAR performance products will help you keep it off the guardrail.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 04-09-2003, 11:37 PM   #5
BaggedC10
Under construction!
BaggedC10's Avatar
Yes, you can make a truck handle very well! Performance oriented springs (Belltech or Eibach), lowered shock absorbers (Edelbrock, Doetsch Tech, or Bilstein), aftermarket anti-sway bars (Hellwig), and a quality lowering kit are a must.
P.S.-Polygraphite or polyurethane bushings for the suspension will also make a BIG difference.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 04-10-2003, 03:27 AM   #6
cdowns
cdowns's Avatar
you could also look at converting to a fully idependant rear that should really help Kugel makes a really nice one pretty resonably priced starting at only around 5grand
Old 04-10-2003, 04:32 PM   #7
69Elky
don't think i'd go that far with irs but maybe a modified hth nascar rear setup
