08-13-2011, 08:02 PM | #1 |
C10 Club Tennessee
How much cut on bottom cup
I know on 67-72's the bottom cup can be 5/8 inches tall. What about on the 73-87's?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-13-2011, 08:14 PM | #2 |
Re: How much cut on bottom cup
I have square body A arms on my blazer and I set the cup in the arm and measured how much I could cut off without rubbing.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
08-13-2011, 08:19 PM | #3 |
mine are 2 inches and they're close to the one side already. that's with 2600's something smaller you might be able to cut it some.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
08-13-2011, 08:48 PM | #4 |
67-72 parts collector,…
I thought it was 1-5/8" total height.
08-14-2011, 12:50 PM | #5 |
C10 Club Tennessee
The reason I ask, and I pretty much knew I screwed up, was that my dumba$$ cut the cup to a TOTAL of 5/8 inch not a 5/8 inch off the original cup.
08-14-2011, 01:37 PM | #6 |
no problem, it's just metal. You can weld it and cut it again. That's the beauty of metal. You can cut it three times and still be too short, but then you can weld it to make it longer.
08-14-2011, 02:43 PM | #7 | |
Sounds like a long process, but it would work.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
08-14-2011, 05:37 PM | #8 |
C10 Club Tennessee
So have we decided on what Keith thinks, no shorter then 1 5/8? I can buy these:
http://*******************/bag-bracke...t-circle-lower and just flip the other pieces over and weld them on. Just want to make sure the 1 5/8 is correct.
08-14-2011, 07:35 PM | #9 |
Bryan.
Make a cardboard template. Easy to cut with scissors and correct any errors. Then you will know for sure.
08-14-2011, 08:20 PM | #10 |
C10 Club Tennessee
I'm confused Keith, I just need to know the minimum height on the bottom cup.
08-14-2011, 08:31 PM | #11 |
Cardboard circle.
(like a halo) 1-5/8" tall. Make sure that is tall or short enough before you cut the actual cup.
08-14-2011, 08:56 PM | #12 |
A guy with a truck
1 5/8" in my experience, too. That said, I would use a template to be 100% sure...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-15-2011, 08:18 AM | #13 |
C10 Club Tennessee
08-18-2011, 09:52 PM | #14 |
Nothing to see here.....
1 5/8" here as well.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
