Old 08-13-2011, 10:52 PM   #1
tucsonjwt
Ignition Lock Cylinder Diagnosis
I insert the ignition key and turn the key, but the key stops at the far end of its travel and won't turn all the way to start the truck unless I pull out the key slightly. Is this a bad lock cylinder for sure, or could it be the connecting rod hanging up down to the ignition switch, and how would that be checked?
tucsonjwt is offline   Reply With Quote
Old 08-13-2011, 11:12 PM   #2
juiceman650
juiceman650's Avatar
Re: Ignition Lock Cylinder Diagnosis
Check your key, if its dull the ignition work turn all the way...happened on my dads 00 Silverado.
juiceman650 is offline   Reply With Quote
Old 08-13-2011, 11:36 PM   #3
tucsonjwt
Thanks. I just tried to start it a few times consecutively with a virgin OEM GM key and it started every time. Maybe it was the key.
Old 08-14-2011, 03:49 AM   #4
juiceman650
No problem, my dad had a brand new spare laying around. He swapped keys and it started every time.
