08-13-2011, 11:23 PM | #1 |
Reversing front trailings arm mounts
I have my chassis all together and painted, and put the wheels on today. I used 3 inch blocks between the housing and trailing arms, with longer ubolts for the lowering of the rear. Kind of a poor mans way to do it but it works. I'm looking at the front of the trailing arms where the big bolt goes through the bracket and the trailing arm bushing. Has anyone ever knocked the rivets out of the mounts on the crossmemember, and bolted the bracket in upside down?? The position of the big front bolt would be exactly 3 inches higher on the crossmember, and lowering the rear of the frame should go down about the same. I don't think pinion angle would be affected much, and I wouldn't have to use the 3 inch spacer block at the rear of the trailing arms. Has anyone tried this??
08-14-2011, 10:17 AM | #2 |
Resistance is Futile
Re: Reversing front trailings arm mounts
It's been done. I think the aftermarket x-members are designed to mimic this type of mod with the mount higher on the piece.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
08-14-2011, 01:15 PM | #3 |
Senior Enthusiast
Here's an earlier thread with quite a bit of input:
http://67-72chevytrucks.com/vboard/s...rm+crossmember |
08-15-2011, 12:51 AM | #4 | |
