08-14-2011, 12:38 AM | #1 |
69 c/10 lwb fleetside
ignition module
buddy brought me his truck 80 or so ton chevy 350 to work on that he just bought and the guy he bought it from just put a module in it and it had been cranked probly 20 times tops and the module has done went out. so i put a used one in it and cranked it less than 10 times and now it is bad. is there something causing this or just taiwain piece of crap modules you think?
69 lwb fleetside 67 swb fleetside (2) 72 lwb fleetside 50 swb no bed 65 impala ss 65 1 ton flatbed |
08-14-2011, 11:18 AM | #2 |
Re: ignition module
I'm not an electronics whiz, but it sounds like the unit is getting too much voltage somehow. I would put a meter on the input and see what's going in. It's a place to start.
08-14-2011, 11:23 AM | #3 |
Re: ignition module
I agree with the meter check. See link in this post for a good way to test coil and pickup. There is no way to test module unless you have expensive tester.
Do you have engine to frame and cab to frame grounds?
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
08-14-2011, 12:53 PM | #4 |
Re: ignition module
Check grounds, check voltage and check ballast resistor if equipped. My best guess is the ballast resistor.
08-16-2011, 08:20 AM | #5 |
Re: ignition module
where would the ballast resistor be if it does have one i have never messed with one of them and how do you tell if its bad.
08-16-2011, 04:10 PM | #6 |
Re: ignition module
You've put the heat paste underneath the module(s) before installing them, right?
08-16-2011, 04:38 PM | #7 | |
Re: ignition module
I am betting that you don't have a module problem at all. I bet you have a bad pole piece or pick-up. Just get another distributor.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
08-16-2011, 10:48 PM | #8 |
Re: ignition module
oops, forgot testing link;
http://www.angelfire.com/realm2/84ca...coil/coil2.htm or, http://www.angelfire.com/realm2/84ca...coil/coil2.htm
