08-14-2011, 02:42 AM | #1 |
Aftermarket gas pedal
I'm looking to buy one and can't seem to find any info through searches. What kind of aftermarket go pedals are you guys running if they're not stock? Show some pics if you have them handy. Full pedal sets too. Cable not linkage.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
08-14-2011, 02:44 AM | #2 |
Re: Aftermarket gas pedal
Your in luck! Someone on here just released news that Lokar is now making the pedals.
Edit:OOps! Im always thinkin 67-72, sorry. might wanna check behind me.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
08-14-2011, 02:46 AM | #3 |
I'll search it out but shoot the link to me if you can find it. Thanks Doc!
08-14-2011, 02:47 AM | #4 |
Sorry, check my edit. I've got 67-72 water on the brain. I dont know if they are a trans plant though.
08-14-2011, 01:50 PM | #5 |
Senior Enthusiast
Here are a few earlier threads on the subject. I communicated with another forum member a while back about the Lokar thru the floor type. Over time he grew to dislike it and took it back out. (For what it's worth).
http://67-72chevytrucks.com/vboard/s...ight=GAS+PEDAL http://67-72chevytrucks.com/vboard/s...ight=GAS+PEDAL http://67-72chevytrucks.com/vboard/s...ight=GAS+PEDAL |
08-14-2011, 04:32 PM | #6 |
Thanks for the links. I saw the first two but not the third. I'm still searching...
08-14-2011, 06:56 PM | #7 |
i have the lokar style thur the floor gas pedal on my classic car(have stock on truck)and think it works great..."glendale" is also running one on his custom car he might chime in about it. It is best to have a buddy to help with the mounting hardware under the floor...i also have found out that having a strong spring on the carb helps with encountering any slop from the cable...also if you have a hot rod shop,import auto store like http://www.tognottisautoworld.com/Default.aspx they have company's like "rpc" that sells lokar knockoff parts which i have found to be as good as for half the cost of lokar heres a link to "rpc" gas pedal on their website.
http://www.rpcproducts.com/product_i...roducts_id=784 check their site out they have tons of stuff
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
