Old 04-08-2003, 02:20 AM   #1
MSL
MSL's Avatar
Question If its not onething its another. tranny
Well all was well until today i get in warm up the truck and now when its warmed up and i go to take off and shift into reverse and it shifts hard really hard .my TH350 might be toast who knows it shifts fine when i put it into drive and it shifts fine when im driving. any ideas to help out.thanks
MSL is offline   Reply With Quote
Old 04-08-2003, 03:06 AM   #2
Mike76251
Re: If its not onething its another. tranny
Darn...
Well at least you don't have that WONDERFUL 700R4!!
All that plastic inside...... Nevermind
If I remember right, 1st and reverse go out together in a 350.
Sounds like your line pressure is too high.
Could be a clogged-up modulater.
Is the filter clogged?
It's not slipping at all?
Mike76251 is offline   Reply With Quote
Old 04-08-2003, 03:19 AM   #3
MSL
MSL's Avatar
I dont think its slipping that seems fine i havent tried to see about to much pressure. as for the filter i havent changed it yet. Im going to do the filter and fluid today and how do i check the modulator to see if its no good.or just plugged. I pulled the tube no metal flakes on it or bad smelling fluid. maybe somethings plugged (crosses fingers and hopes)lol
Old 04-08-2003, 09:38 AM   #4
Mike76251
I was just looking through a shop manual on your problem...
One thing you need to check is the Vacuum Modulator.
If the diaphragm in that thing goes it can cause hard shifts.
You get a pipe cleaner or something and pull the vacuum hose off it and stick it in as far as you can. When you pull it out it should not have any trans fluid on it. If it does then get another.
If the fluid has not been changed in awhile, I would recommend a high quality fluid 'cause they typically have good cleaners in them and your trans may just need that. I use Mobil 1 synthetic but that stuff is high.
Here is a pic out of the manual of the modulator,
Old 04-08-2003, 09:47 AM   #5
Mike76251
924
Old 04-08-2003, 09:49 AM   #6
Mike76251
Here is a little check list from the manual for you on high line pressure,
Old 04-08-2003, 02:05 PM   #7
1FaastC10
1FaastC10's Avatar
Re: Re: If its not onething its another. tranny
Originally posted by Mike76251
Darn...
ah, yet another misinformed opinion running down the 700R4/4L60... there wasnt any more plastic inside the 700R4s i've been inside than any TH350 or TH400 i've ever seen. you just have to make sure that the clutch clearances are good and the TV cable is properly adjusted, and the 700R4 should be just fine behind a mild small block.
1FaastC10 is offline   Reply With Quote
Old 04-08-2003, 04:08 PM   #8
Mike76251
Re: Re: Re: If its not onething its another. tranny
I guess I shouldn't have put it like that....
I know there is no plastic in one but maybe that would be stronger than the stamped and thin cast stuff in there.
I put $1150 in one of those pieces of s**t.
A stock 305 blew it up!!! My lawn mower has more torque than that!!
I took it apart and could not believe the cheap crap in there.
They are good(?) trannies if you put $700 worth of upgrades in there.
You should not have to do that.
I have put 400 ftlbs of torque through a stock+shift kit Turbo 350 and the car is still going 15 years later.I also have a Auto box called a "Slim Jim" in my '62 Starfire. That car has it's original tranny and it puts out 440ftlbs. It too is still going 40 years later.
Try that kinda torque with a stock 700R4 for even 6 months and you will break a record (and a tranny).
Misinformed....My wallet doesn't think so.
Old 04-09-2003, 12:51 AM   #9
MSL
MSL's Avatar
Appreciate the help i just got done channging fluid and filter and the modulator we are all running good in the tranny dept for now. i need to get a new tranny mount the rubber is cracked and worn out so i have a little play there. thanks for the help and pics.
Old 04-09-2003, 12:52 AM   #10
MSL
MSL's Avatar
Guess i should say the fliud and filter where nasty hasnt been changed for awhile. and i hate those stock tranny pans without a plug i get tranny fluid on me all the dang time.
