08-14-2011, 11:54 AM | #1 |
72GMC51
Fuel tank venting
If I plugged the Vapor return lines on my 72 GMC and didnt have a vented cap, could the pressure build in the tank to a point that it would be able to push fuel passed the fuel pump (edelbrock that is supposed to have a preset pressure of under 5psi) and push gas pass the float seat and flood the engine?
Thanks John
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished |
08-14-2011, 12:02 PM | #2 |
Grandpa in the rustmobile...
Re: Fuel tank venting
Gonna jack ya thread..
when I loosen my gas cap to pump gas i can hear the pressure BLOW thru the cap and the gas tank expand again.. could this be bad "
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-14-2011, 12:58 PM | #3 | ||
"I ain't nobody, dork."
The '70 to '72 trucks had an EEC system that vented the tank externally and not from the cap. So if you pulg all the lines (like I did in my '72 GMC) you will ned to use a vented cap.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
08-14-2011, 01:33 PM | #4 | |
Active Member
When you buy a cap, let them know you want a vented one. Usually the NAPA and CarQuest people will carry it or can order it. Not sure about Auto Zone or O'reilly. In response to oldblue1968chevy: You say it "blows" when you remove the cap and tank "expands" again. That's contradictory. It probably "contracts". Anyway, a "whoosh" of air being released when the cap is removed, that too is an indication that the tank is not venting properly. Too much pressure can also create too much vacuum and the fuel pump has to actually work harder to overcome it. In some cases, if you have weakened areas in the tank due to rust, the pressure can cause failure of the metal and create fuel leaks. |
08-14-2011, 01:49 PM | #5 |
Soo...
I need a vented cap? (Darn I scored my current one for a dollar a at yard sale brand new)
08-14-2011, 03:59 PM | #6 | ||
Sounds like it. Could also solve all the fuel pressure probs you've been havin' too.
A cap at a yard sale? Meh... go buy a new vented one. Gary
08-15-2011, 03:38 PM | #7 |
72GMC51
So now that we have settled the question of the guy who jacked my post does anyone have an opinion on my original question?
08-15-2011, 05:22 PM | #8 | |
Active Member
Anyway, yes, it is possible to force gas into the carb with too much pressure but worse, it could cause a leak into the engine oil pan to occur. In this hot weather the tank could create enough pressure to rupture the fuel pump diaphragm especially if it was aleady weak. As I mentioned in the other post, it could also lead to gas tank failure if the insides were already weakened from rust. |
08-15-2011, 05:57 PM | #9 | |
72GMC51
Thanks Again JC
