Old 04-08-2003, 04:48 AM   #1
lost wages
lost wages's Avatar
2 link bars
ive seen alot of sites where they are building 2 link set ups for trucks, what if i were to take the trailing arms on my 68 and mount them up to the outside of the frame rail? my main reason for wanting to do this is to open up all the space inside the frame for exhaust since my truck has air bags and a step notch. It would also leave more room for the air tanks and compressors. What do you all think of this idea?
lost wages is offline   Reply With Quote
Old 04-08-2003, 08:33 AM   #2
Randy70C-10
Randy70C-10's Avatar
Not 100% sure, but I think that they were put on the inside for triangulation. It seems that if you move them to the outside, it could make them more prone to getting tweaked. (I'm guessing)
Randy70C-10 is offline   Reply With Quote
Old 04-08-2003, 09:04 AM   #3
crazy longhorn
Fabricate till you "puke"
The 2 link setups I have seen use a pretty stiff 2x3 rectangle tubing(I think 1/4 wall). I agree with Randy, the stock arms may get tweeked if you are running them straight. Also, you may sacrifice a little ride quality,as the rear diff wont" rock" , or work independently over the bumps. my guess is it would ride more like a leaf sprung truck(tend to hop a bit over the bumps). i have thought about building a set of long bars for the longhorn, & run air bags for traction help. look at IFS custom site, & they show using an old leaf spring eye & bushing, welded to the bars for the front eye. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-08-2003, 01:31 PM   #4
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Um, I know you don't ever listen to me, but stop being a tight wad and order the four link set up from somewhere and lets put in there this weekend. I know, I know, you can build your own, but we will all be old by then!! LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 04-08-2003, 03:33 PM   #5
Jesse 67 c-10
Jesse 67 c-10's Avatar
I was also wondering about that, Triangulation shouldn't matter cause you have a track bar, but the mounts would have to be pretty strong. You would also have to re-do your axle brakets. 4 link would be easier and better.
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 04-09-2003, 01:56 AM   #6
lost wages
lost wages's Avatar
4 link is on the way, you all heard 1971 stepside, hes going to help this weekend.of course his idea of help is drinking a latte and *****ing about rust.
Old 04-09-2003, 09:31 AM   #7
1971Stepside
Almost Satisfied
uh, did I say this weekend? What I meant was.....I guess I'm still in shock that you took my advice.
Yo! Lets go get that truck Friday late afternoon! I can get off work early Friday (around 3) if you would be ready to roll at that time.
Oh, you buy the latte!
Old 04-09-2003, 11:41 PM   #8
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
Hey, someone has to do the *****ing!!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 04-10-2003, 02:33 AM   #9
lost wages
lost wages's Avatar
i ordered the pete and jakes trianulated 4 link, i just got done( is that proper english?) making a template of my frame so i can box in the last few feet of frame rails.They said the 4 link will be here tommorow( they are only a few hours from here). I got on the horn and located a 9 inch ford( yeah i said it) rear end. I have a thirdmember with a new eaton posi and richmond 4:11 gears. That should keep me busy this weekend.
Old 04-10-2003, 09:40 AM   #10
1971Stepside
Almost Satisfied
uh, I'm not feeling well all of the sudden......
