08-14-2011, 04:19 PM | #1 |
Engine knock, HELP!
bad knocking sound coming from inside block it seems. I thought was a loose vavle/rocker at first but def not after removing both valve covers. truck actually runs fine as in not missing or loping however is a really bad knock almost clacking sound. if would be a piston issue wouldnt truck be missing a little? Any sugestions would be greatly appreciated. Tomorrow i will be taking it to my uncles mech shop to get further into issue.
Posted via Mobile Device |
08-14-2011, 04:23 PM | #2 | ||
"I ain't nobody, dork."
Re: Engine knock, HELP!
Rod knock is on the big end of the rod at the crank. Spun bearing. The longer you run it, the more damage is being done. A rod knock will dissappear slightly under power, and then get very loud as you come off the pedal. Will also be a constant at idle.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
08-14-2011, 04:41 PM | #3 |
Thanks for the quick reply, the knock seems to be very inconsistant. not very loud at idle but def can hear it and when you press on gas it gets louder. Spun bearing would cause this type of issue? i hope it is that b/c i dont imagine that hurting my wallet too much as far as parts right?
08-14-2011, 04:44 PM | #4 | ||
A spun bearing is a complete engine teardown and rebuild... so it hits the wallet pretty hard.
So it does it when the engine is under power? Gary
08-14-2011, 04:51 PM | #5 |
Yes, the knock/clack gets much louder under power. what really throws me off is it starts n idles fine minus he very loud knock.i literally thought there was a loose bolt or something just being knocked around when the sound started. I will see if i can fgr out how to post a quick video in hopes of you being able to hear it. I really appreciate your help so far.
08-14-2011, 05:00 PM | #6 |
If it is a spun bearing, you will need to rebuild the bottom end, more than likely requiring machining of the crank (engine pulled from truck). Not an inexpensive fix. If you are going to do that and the rings, pistons and bores are okay, you might as well change the cam, timing gears, chain, oil pump and lifters unless they are realatively new. Cam, lifters, timing set, oil pump, install lube, cam break in lube, full felpro gasket set can be had from Summit for about $200 if you use their brand. Bearings an machine work on the crank will be more. You will have to see how much the crank has to be cut to know what size bearings you will need. Good learning experience for you if your Uncle can assist you.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
08-14-2011, 05:34 PM | #7 |
08-14-2011, 05:55 PM | #8 |
454 MAKES IT ROAR
Would a lobe have gone on the cam, or maybe a stuck lifter?
Or damaged push rod. It doesn't sound like bottom end noise.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger Last edited by eightbanger; 08-14-2011 at 06:03 PM. |
08-14-2011, 06:25 PM | #9 |
Check your torque converter bolts!
08-14-2011, 07:09 PM | #10 |
Looks like it is internal there is no oil come from the push rods
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
10-15-2017, 12:16 PM | #11 |
Did you ever find out what the problem was? I have a similar sound where it’s inconsistent but it goes away under load.
