08-14-2011, 07:13 PM | #1 |
To Sealant or Not?
Ok finally getting ready to assembly engine. I have a tendancy to put sealant on all mating surfaces.
I need some advice Head gasket Do I Put sealant Side cover gasket Oil Pan Fuel Pump Timing Cover Gasket |
08-14-2011, 08:13 PM | #2 |
Re: To Sealant or Not?
Head gasket - NO
Side cover gasket - Yes, a light film Oil Pan - Yes, a light film. More at the front and rear. Fuel Pump - yes Timing Cover Gasket - yes I do this on all engines i assemble and never had any leaks. I NEVER glob it on. I only apply a light film on anything i do. The trick is not to over tighten. |
08-14-2011, 10:15 PM | #3 |
one note - I like to put the sealant only on the pan side of the oil pan (kinda like a BIG valve cover...), then attach it to the oil pan - let it dry a bit and then stick it on. Don't go crazy with it, Zack's spot on with the light film comments. And then - DON'T overtighten. I put that in bold because I always tend to do that.... That will split the gasket in a heartbeat.
08-15-2011, 08:26 PM | #4 |
I have the manual right in front of me. On page 6-26 under the installation section it states to use a good head gasket paste sealer with this gasket.
Interesting most folks say no sealant and the factory is saying yes. |
08-15-2011, 08:34 PM | #5 |
I think that may have something to do with a factory warranty situation. I have NEVER used any kinda of paste or sealer on head gaskets in all my years of putting engines together. If you are still unsure, there is no problem doing exactly as the manual says. I guess it boils down to personal preference. Either way will work fine though.
08-15-2011, 08:39 PM | #6 |
I believe there is a difference between "sealant" and "paste"... Buy by the produce description in the manual if you must - BUT, the manuals were written in the 60's when head gaskets (of the day) required sealant.
Read the instructions with YOUR head gaskets and follow them, times have changed. I am with Zack - most go on dry. Have seen some cases where in a tack was applied to hold them in the proper place, but the dowels should do that just fine. Again, I do believe that the instructions with your particular head gaskets trump our 1960's shop manuals. If no guidance provided with your gasket - then I recommend you dump all this guidance and call the manufacturer with your part number and ask them specifically. For clarification - are you reading a manual that is for your specific gaskets or are you reading the 60-66 shop manual? |
08-16-2011, 12:44 PM | #7 |
the old steel shim type head gasket does require sealant but the newer composite gaskets do not use sealant nor do they require a re-torque
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
