Old 08-14-2011, 08:11 PM   #1
Louisianaboys69
Louisianaboys69's Avatar
how low can you go?
got a 69 swb all factory suspension, looking to bag it while its frame off. question is how low can i get with just installing bag on fact. set up with a c or z notch in the rear. This will be my first attempt at this, i have been reading the forms to see what others have done. but know one has really said how low they can get it with fact. set up. i know it will not lay frame but houw low will it go?
""Don't Tread on me is how live and i'll take it to my grave""
My restoration video....... http://www.youtube.com/watch?v=tU9fhHcDivs
Louisianaboys69 is offline   Reply With Quote
Old 08-15-2011, 12:34 AM   #2
SCOTI
SCOTI's Avatar
Re: how low can you go?
They'll drop until the lower control arms hit the ground (w/stock arms, they're the 1st things that hit). This will typically leave the frame rails several inches (2-3) above the ground.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-15-2011, 10:34 AM   #3
Louisianaboys69
So if i c or z the rear, and bag it fbss. Could I just weld in some stops to acheive a ride hieght or eliminate the arms from grounding out and still be abut 2'' or close from ground zero? I know spindles are the way to go and will change them out later with brake/disc upgrade just want to get my bags going for now will this be unsafe or a bad idea, money is always the problem or should i say the hold up.
Old 08-15-2011, 10:53 AM   #4
SCOTI
SCOTI's Avatar
Even w/spindles, the lower a-arms will be the first thing to make contact w/the ground. At that point, you'll still be more than 2" from the ground @ the frame rails.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2011, 11:12 AM   #5
Louisianaboys69
So which would you prefer?
Old 08-15-2011, 11:16 AM   #6
SCOTI
SCOTI's Avatar
The fewer corners, the fewers areas for stress related failures to start. Round gets the vote if/when possible....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2011, 11:23 AM   #7
Louisianaboys69
I would have to agree, the cups look as if they would be a lot easier to build too. Would you know if there is a standard cup size or if they vary with bag manufactures?
Old 08-15-2011, 11:41 AM   #8
SCOTI
SCOTI's Avatar
Since front bag sizes vary, you'll want to go as big as possible (8" dia is where I would start).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2011, 11:44 AM   #9
Tony@AirRideTech
Junior Member
You may want to drill some drain holes in there
Tony@AirRideTech is offline   Reply With Quote
Old 08-15-2011, 12:05 PM   #10
Louisianaboys69
You talking about the round cups? and other than the existing bolt hole your suggesting I drill one or more hole to allow drainage from the lower portion of the cup?
Old 08-15-2011, 12:43 PM   #11
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2011, 12:46 PM   #12
Louisianaboys69
Scott what size bags do you recomend f v/s b? i think the kit im looking at is same all way around, not real sure. I'm going to look but would like your input. they are airlift D2600 all four do you know the diamiter of the base of these bags?
Old 08-15-2011, 12:55 PM   #13
SCOTI
SCOTI's Avatar
63-72 GM 1/2 ton truck = ~7" bags in front (RE-7's or Firestone F6783/224c or equivalent); ~6" bags in the rear (RE-6's or F6781/255c Stones).
63-87 fronts are the same recommendation. Rear leaf trucks need an AOL set-up or suspension swap for bags.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-15-2011, 10:47 PM   #14
tubbedII
needs more $$$
tubbedII's Avatar
I got D2600 air lifts all around on mine. Front has 2.5" drop spindles and rear has 2" blocks with a c-notch, nothing else to make it lower. This is how low it gets with a 29" tall tire, so a shorter tire/wheel combo will yield a lower stance. The stance is pretty level without the cupped LCAs.
I have a set of cupped LCAs, but I haven't redone my exhaust in order to use them. Right now I can air it out without dragging the long tube headers. Also, the Air Lift D2600 balloon out pretty far, so something a little bigger than 8 inches is better if you end up cupping the LCAs. I went with the rectangular type since they allowed a bigger opening.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
